Results 1 to 6 of 6
Reload Thread: Audiobahn AW1051T - Help quick plz
    xplicit's Avatar
    xplicit is offline Member
    Apr 2003
    erlanger ky
    28
    109
    are these decent at all??
    10” NATURAL SOUND WOOFER
    45 oz. Strontium Magnet
    Power Handling: 300 watts R.M.S.
    Frequency Response: 28Hz - 1kHz
    Efficiency: 91 dB
    PHAT Foam Surround
    Non- Pressed, Non-Transfer Paper Cone
    KM3’ Coated for Virtually No Cone Distortion
    2” 4-Layer ASV Voice Coil
    Dual 4 Ohm
    2 Ohm or 8 Ohm Operation
    Mounting Dimensions: Depth; 4 5/8” Hole; 9” Diameter; 10 1/4”
    Lug Lock Terminals
    PATENT PENDING
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Depends on what you're looking for in a sub and how much you have to pay/how much you are getting them for.....in my humble opinion, they look better than they sound....
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    gellis4's Avatar
    gellis4 is offline *how peculiar*
    Mar 2003
    NH
    28
    1,211
    They are O.K, but not great.
    totally agree.
    '92 Wrangler
    35" BFG's
    Check the Wrangler
    xplicit's Avatar
    Apr 2003
    erlanger ky
    28
    109
    gaunlet
    i currntly have two ten inch mtx thunder4000's... i have a chance to get two ten inch of those audiobahns today... will they be a good improvement from the mtx's?
    gellis4's Avatar
    Mar 2003
    NH
    28
    1,211
    more than likely.. but i don't know. The MTX will probably sound better.. but i have not heard 4000's, i've heard a lot of 'bahns, and didn't like any of them (sound really muddy). Just my personal opinon.
    Ask to hear them first, hook them up, if possible, and then compare//contrast what you like. That's my best advice for ya.
    '92 Wrangler
    35" BFG's
    Check the Wrangler
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Re: gaunlet
    Well....overall it won't be a huge improvement....SPL will probably be a little better....SQ will be a little worse......if you're doing a straight-up trade type of deal, I would do it simply b/c neither of those are SQ subs, so you might as well get the louder of the 2....but if you have to pay more to get the 'Bahns, I'd stick with the MTX since neither is significantly better than the other in any one area...
    Basically...
    - Slug
