View Poll Results: 5 cubes sealed or 8 cubes sealed?
Voters
12. This poll is closed
  • ~5 cubes sealed
    10 83.33%
  • ~8 cubes sealed
    2 16.67%
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 53
Reload Thread: Decision time with sealed box: 5+cubes or 8+cubes
    BreakingBad's Avatar
    BreakingBad is offline Banned
    Aug 2006
    pittsburgh
    1,230
    10 Post(s)
    have had many threads about this, back and forth on what i should do.
    the conclusions to those threads were: DONT go with 8 cubes and GO with 8 cubes.
    I wanted sound quality out of my 18" XXX, so the majority of people said go sealed because on top of that, it will have more of a "pound" but won't get as loud as a ported.
    SO, being said, i have designs for both 5 cubes and 8 cubes thanks to immacomputer <props to him, very helpful guy
    anyway, i am dropping off the plans tomorrow probably, but it's decision time - 5 cubes or 8 cubes.
    the main difference is the low end.. the larger box will apparently wang a lot harder on the lower freq's, while the 5 cube won't go AS low, but will hit the higher freq's a -little- better than the larger box.
    SO, what would you do in my situation if you had to go sealed (ignoring ported all together) vote and post your response
    dbhittin's Avatar
    dbhittin is offline Banned
    Apr 2002
    Van...Wa
    34
    5,828
    Re: Decision time with sealed box: 5+cubes or 8+cubes
    8 cubes seems way to big for sealed, so id say 5
    Aug 2006
    pittsburgh
    1,230
    10 Post(s)
    Quote Originally Posted by dbhittin View Post
    but what people have said is that 8vs5, you'll have a much much much better low end response which will give me the "earthshaking" sound im going for.. or can 5 cubes do that also?
    Blados's Avatar
    Blados is offline CarAudio.com Veteran
    Sep 2004
    Baltimore
    3,910
    8 cubes would be retartedly ridiculous. Go with 5.
    References:mb7, Moe Lester, Untouchable11, jntar,BC_BIGBUDZ420, cobra65427289, zebo, sku, theFBI
    bcarpenterfhl PDizzle2oo5, KngOfThePkngLot, Iamamp3pimp, kinville, ArrizX, boomzilla, stuckinok, NMBR1SPT, ls2poweredgoat, BushJ311, MTXman, lookitsjim23, jeepintn, violentrapture, Dtowncats, wgsj_fortvalley
    jdc753's Avatar
    jdc753 is offline Truck Brigade
    Nov 2006
    Mass
    33
    1,891
    either way your building a big box but I would go with 5 cubes 8 would probably sound more like a ported box just minus the output, 5 will give you the quality your looking for, and I'm sure enough output if your running a 18" sub with its recommended power
    2005 F350 crew cab diesel 4x4
    -Work in Progress-
    HU: Alpine 9887 linked to 10.4" TS TruckPC
    Front Stage: Polk SR6500 Active
    Front Amp: Sundown Sax100.4
    Sub: Stereo Integrity Magnum V4 in the center console
    Sub amp: Sundown Saz-1500D
    Refs: low_end, Relax, SSon22s, Johnson, tyroneshoes, twisztdpunisher, flakko, djhn9, KINGDELL91, amoffitt, Justin89T, 01 S 10, Mazzasec
    Aug 2006
    pittsburgh
    1,230
    10 Post(s)
    those of you unfamiliar with the sound i want:
    i want to literally shake everything with this sub. this sub DOES have the ability to do that, and what some people were saying is the 8 cube will do that much better than the 5... or would the 5 do it just as good?
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    What is the Qtc alignment for either choice?
    I'm a fan of very low Qtc alignments, but I also like subwoofers crossed over very low...40Hz-ish...
    Aug 2006
    pittsburgh
    1,230
    10 Post(s)
    Quote Originally Posted by JimJ View Post
    for the enclosures? no idea, immacomputer designed them..
  9. #9
    SeanDub's Avatar
    SeanDub is offline CarAudio.com Veteran
    May 2006
    Kansas
    29
    3,526
    2 Post(s)
    Quote Originally Posted by sublime06 View Post
    Then do 8 cubes ported at 32 hertz.
    Sealed boxes also lose power handling, and 8 cubes is retarded for a sealed box. If you must go sealed, go with 5 cubes.
    Deck: Pioneer Premier 880 w/ iPod
    In-dash: AudioControl Epic-150
    Sub: Digital Designs 9515e/f Dual 1.0
    Amp: Atomic 5000.1 @ 0.5 ohm
    Box: 3.85 @ 36 hz with 66 sq in of port
    Refs: fwb_1234, Hopes Audio, Louisiana_CRX, astrolade, nhustlar, teamquakecelica, walkychalky, negative3five, TypeRBass, jblanford (x2), massiveaudiocw, KnOkIn It 420, hoss, xtremebassjunky, trow100, MillzThaYungin, IonSQL, matrxx dude, yunvme666, vitveet, PWNED, Team H&K, jk32sho
  10. #10
    Supergumby5000's Avatar
    Supergumby5000 is offline Project: F350 begins...
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    if you want to shake ****, just port the **** thing and tune low
    i wouldnt go 8 cubes sealed though
    Project: Avalanche V1... http://www.caraudio.com/forum/showthread.php?t=345189
    Project: Avalanche V2... http://www.caraudio.com/forum/showthread.php?t=432321
    Project: F350... Coming Soon!
    Need a box or box design? -EMAIL- me for info/quotes, do NOT send a PM
    my username @ hotmail.com
  11. #11
    Aug 2006
    pittsburgh
    1,230
    10 Post(s)
    Quote Originally Posted by Supergumby5000 View Post
    a lot of people will disagree with you on that aspect.
    ported's are also very peaky, and thats the last thing i want. sealed's apparently have a much better frequency response through all the frequencies than ported's do.
    i dont care to get super loud, but most people have said previously sealed will have better SQ, respond better on the lower freq's and shake the **** out of things too..
  12. #12
    Aug 2006
    pittsburgh
    1,230
    10 Post(s)
    Quote Originally Posted by SeanDub View Post
    not 'shake' as in get loud and just rattle stuff.
    i want that sound where you dont HEAR me coming, you FEEL me. THAT kind of shaking.
  13. #13
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    I'd try 8 cubes at first...
  14. #14
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    i've used both ported and sealed, on many different occasions, in many different vehicles. I reccomend ported. To have an XXX in a sealed is just an insult to the sub
  15. #15
    IgnoreMe's Avatar
    IgnoreMe is offline I love 2 girls 1 cup
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    you guys really have to read the other thread then.
    this sub is NOTHING like the 05 and back xxx's. it doesnt react the same way and almost everyone with knowledge on how to use t/s specs to get an idea of what enclosure is best says to seal the 06 and up xxx's.
    i was arguing for a while that i see no point in sealing an xxx either (at least for my tastes) especially since ive had experience with the 05's. but many of the more respected guys said the t/s parameters BEG for a sealed enclosure and i would take their word over mine when it comes to an unfamiliar sub, so i did.
    llllllllllllllll Educate yourself and help stop the ignorance.
    llllllllllllllll DEA Judge Francis L Young says...
    llllllllllllllll Designing a Ported Box
    refs: hazardous0388, snoopdan, karleon, thelow, freezeman_7, imtjnotu, Gebrochen, astroladespl, billabongcr , mustbenu , thunder9500 , 91ser, djdilliodon (6 times), stupify, milenko515, Zeuslicious, Bmoorman05, WaTTsLOk187, too dope 1904, nate2587, rbiele126, denalilvr
    Don't Blame Me. I Voted for Ron Paul.
    BluePoint Air Ratchet for sale...click me bitch
