I have a battery in the back at the amps. I would like to use my dmm to check the grounds. To clarify, do I need to disconnect the battery before I check the resistance?
2002 Chevy Tahoe
System in progress:
Skar 12's (?)
Sudown 1500d and 100.4
Pioneer Premier 880
Mb Quart QSD
no you should actually measure the voltage drop across your system while it is under load to test for a good ground location.
"humility in the face of overwhelming genius will obviously amount to hypocrisy"
Good Information..
any info on where to ground on a 2006 pathfinder?
in my 98 Eclipse i just used the factory bolt right under the trunk floor on the left side, i used a 4awg battery terminal and sanded the paint off the trunk floor and bolted the ****er down. i only used 3' of 4awg wire for ground and 17' for the positive, kept the cost down. but Eclipse Spyders are the WORST cars to get loud because theyre soft-tops.. but it works i guess. the MOFO hits pretty decently
Bookmarks
