+ Reply to Thread
Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 101
Reload Thread: How to properly make a ground!!!!!
  1. #46
    bass-aholic's Avatar
    bass-aholic is offline CarAudio.com Veteran
    May 2008
    New York
    2,018
    5 Post(s)
    Re: How to properly make a ground!!!!!
    Quote Originally Posted by theothermike View Post
    this is supposely lots of bad info. in regards to running a ground length. i will say this. the - on the battery is not the ground. the ground in and of itself if the whole car in the miss meaning mostly the chassis and frame.
    so if u run a ground run throughout ur car. make sure u upgrade you battery - to frame negative connection with larger wire.
    wat?
    Synyster97XLT
    Science can fly planes across oceans. Religion sends them straight into buildings.
    2 18" btl's
    10^3 35 hz
    2 GP3000d pro's.
    250 amp alt
    3 extra batts
    8 5" dayton mids
    Rockford p300.2
    All knu fleks 1/0
    CD-IB100II
    Refs and feedback \/
    http://www.caraudio.com/forum/showthread.php?t=431785
  2. #47
    May 2008
    New York
    2,018
    5 Post(s)
    Re: Missing Pokemon Figures, Help!!
    Quote Originally Posted by rangrang View Post
    I am in need of 10 different pokemon figures. I am missing Pupitar, Pineco, Snover, Azelf, Golem, Ralts, Claydol, Aron, Zapdos, and Budew. I was thinking about buying a collection from this LDU Company in China but I really don't need 288 pokemon figures, and that is the smallest collection that I see them listing on their website www.LDUcompany.com
    I am trying to find a place to buy just the ten that I need. Has anyone ever bought pokemon characters from this LDU website? Oh yeah, here is a link to the page with all the pokemons http://www.liangdianup.com/pokemons_1.htm
    Any ideas please post and let me know
    ohhh sweeet dude pokemon....
    Synyster97XLT
    2 18" btl's
    10^3 35 hz
    2 GP3000d pro's.
    250 amp alt
    3 extra batts
    8 5" dayton mids
    Rockford p300.2
    All knu fleks 1/0
    CD-IB100II
  3. #48
    qkassidyw's Avatar
    qkassidyw is offline MECP Master Certified
    Aug 2008
    Seattle
    443
    I don't know if this has been mentioned but a factory bolt is NOT a good ground. Using the bolt will add resistance to the ground possibly adding noise and will most likely not be as secure as using self tappers.
    Also, you should add to the original post a "Look twice, drill once" ALWAYS, ALWAYS look under the car at where the gas tank is to determine if your screw will come near it. On many mid 90's GMS's and Lincolns the gas tank is pressed RIGHT up against the trunk/backseat area.
    And, do not use just a self tapper, use a self tapper and a star washer, this will prevent it from coming loose. The method I use though is to use three self tap screws. One through the ring terminal, one on the right, and one on the left pinching the ring terminal down.
    Finally, you should mention the ground should be as short as possible (18 inches at most) and matching gauge to the power wire.
  4. #49
    Jakeeck's Avatar
    Jakeeck is offline CarAudio.com Elite
    Nov 2008
    Eutopia
    698
    ok now after reading that and using google images to find out what everything was.. i know how to make a ground.. but what is the point of grounding.. why do i need to do it during installation
    yes im an electrical noob.
  5. #50
    OOOKKK's Avatar
    OOOKKK is offline Junior Member
    Dec 2008
    CHINA
    Brass air fittings
    Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
    of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
    used some of the parts to make my babington wvo bu
  6. #51
    donpisto's Avatar
    donpisto is offline CarAudio.com Veteran
    Jun 2006
    Los Angeles, CA
    34
    5,316
    1 Post(s)
    Quote Originally Posted by Tehgregzor View Post
    Well the grounding to the - side of the battery is the BEST ground. It will always be better than ANY sanded metal. Because when you attach that wire to the frame...guess where it ends up. Thats right, the - side of the battery. So might as well skip all the frame and just use nice thick dedicated wire for your ground. Of course, its no miracle worker, but going from a ****** ground to a superior ground can make some difference.
    Old post, I know, but to help newbies it is HIGHLY vehicle dependent. Some vehicles are fine by running a ground somewhere in the trunk, it's hard to tell what would be best, whether from the trunk or the negative battery terminal under the hood. Only way to tell is to measure voltage drop at each location.
    Reason why it is vehicle dependent is because there may be paint, plastic parts and whatnot that are attached directly to the chassis. In some vehicles, that is not the case, in which it would be wiser to run the ground in the trunk since you save money by not having to buy 13+ ft of wire.
    Shyne Fitment Consulting, LLP. ...... More ass than class.
  7. #52
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    Re: Brass air fittings
    Quote Originally Posted by OOOKKK View Post
    aight
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  8. #53
    jaredcroop's Avatar
    jaredcroop is offline Skyline R34
    May 2008
    Glen Allen, VA
    59
    i think the best way to make a ground is to drill that sucker right to the gas tank.. then you know when something goes wrong XD
    "There will be only a demand for maybe 5 computers worldwide they have no use" some ******* from ibm a long time ago
    No car are you selling?
    Engine: one speed bike
    Subwoofer: two pioneers glued to my bike
    Amplifier:made from rubber bands
    I NEED A CAR
  9. #54
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Quote Originally Posted by twisztdauthorit View Post
    don't drill into your gas tank like i did :o
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  10. #55
    jvk5o1's Avatar
    jvk5o1 is offline MAXIMUM PRESSURE
    Feb 2009
    shreveport, la
    63
    when all else fails you can always go to the seat belt bolt or to the battery. you already know they go directly to the frame.
    work smarter, not harder. that doesn't require being mecp certified for that, just common sense.
  11. #56
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    Quote Originally Posted by jvk5o1 View Post
    Please see post #48
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
  12. #57
    01 S 10's Avatar
    01 S 10 is offline LOUD
    Jan 2008
    Central Florida
    30
    4,278
    2 Post(s)
    I just checked my ground in the rear with my DMM. im getting 0.1ohm with the way i have it set up now (1 run of positive only to the rear batts)...
    but.. i used a spare piece of 2/0 and used it as a temporary ground from front to rear (so 1 positive run, and 1 negative run now) and i measured it again at the rear batts, and its measuring -0.1ohm (negative 0.1ohm). is that correct? i thought 0 was the lowest.
    heres a pic of what i did,
    first one is how i have it setup permanently, second is what i tried temporarily:
    is -0.1ohm better than 0.1ohm for a ground?
    -2005 GMC Sierra SLE crew cab
    -Pioneer Avic-d3, factory BOSE
  13. #58
    01 S 10's Avatar
    Jan 2008
    Central Florida
    30
    4,278
    2 Post(s)
    ^^^^ anybody know if -0.1ohm for ground is better than 0.1ohm?
  14. #59
    qkassidyw's Avatar
    Aug 2008
    Seattle
    443
    Its the same thing, its your meter acting odd, it probably initialized differently than before.
    Or you switched the way your leads were measuring the resistance.
    A DC resistance has no polarity so there is no +/- Measurment.
    07 F150 Extended Cab FX2 Sport
    Kenwood KDC-BT945U - And that's about it...
  15. #60
    theothermike's Avatar
    theothermike is offline I HAVE NO LIFE, CA = LIFE
    May 2006
    Tampa
    1,557
    the -.1 and .1 are the same. u crossed the red and black leads somehow either at the multimeter or at the source point.
    Or ur multimeter is running low on batts and is acting funny
    System:
    Fronts:ID Oem's & TBI Hdss Front Amps: Sundown Sax 100.2 & 100.4
    Subwoofer: 2x 12" Fi X D4s Sub Amps: Sundown Saz 1500D
    Headunit: Alpine CDA-9887 Batteries / Alternator: Powermaster / Mechman
    Deadener: Raamat BXT Ensolite Alarm: Clifford 50.5x
    References:
    -Premieraudio-Sundownz-Iamamp3pimp-Kpr10is-Jmanpc- MemphisLove-Greekpower-The 727 Kid-Gixxer9-Mobieous-Audiobahnuser18-Thewes-Steveyhustle-Gymfreak101-go_go_thrash
+ Reply to Thread
