Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Bass Boost?
    peder25's Avatar
    peder25 is offline Member
    Jul 2007
    charlotte,nc
    85
    Bass Boost?
    I am running 1 kicker l7 15in sub with a alpine mrd m1005 amp. When the head units settings are normal with no increase in bass it is not loud, but when i turn the bass settings all the way up it sound awsome, it sounds like a totally different sub. I know this subs can take alot more power then what i am giving it so why do i read that it is bad to use bass boost?
    NewToTheGrounds's Avatar
    NewToTheGrounds is offline Senior VIP Member
    Feb 2006
    Canada,ON
    409
    Re: Bass Boost?
    use a search button for that theres alot of yes and no to that unless sum one feels like posting about it
    _______________________
    H/U: Panasonic
    Amp: Hifonics BXi 1606D
    Subs: 2x12" Clarion Pro Series
    Components: Stock/In Progress
    Component Amp: Sony 3/4
    Battery: Stock
    Encloser: 5ft cubed tuned to 32Hz
    peder25's Avatar
    Jul 2007
    charlotte,nc
    85
    Re: Bass Boost?
    i have searched, i guess my question is if you know you can give your sub more power, is there any reason to not use the bass boost?
    Rich B's Avatar
    Rich B is offline CarAudio.com Veteran
    Oct 2006
    *under the rainbow*
    6,201
    19 Post(s)
    Re: Bass Boost?
    Quote Originally Posted by peder25 View Post
    If you didnt set your gains with the bass boost on you run the risk of clipping the amp, and possibly damaging your sub.
    <img src=http://img.photobucket.com/albums/v81/pintobean/feliz_ano_novo.jpg border=0 alt= />
    peder25's Avatar
    Jul 2007
    charlotte,nc
    85
    Re: Bass Boost?
    what exactly is clipping? and how do i know if i am clipping the amp? and btw it is the settings on the head unit i do not have a bass nob, if that makes any difference?
    XanderMoser's Avatar
    XanderMoser is offline Poor college student
    Mar 2007
    Wisconsin
    573
    Re: Bass Boost?
    The bass setting on the head unit is a 1 band equalizer, same thing as a bass boost knob. Unless it is your subwoofer level output, that is different because it would control the level of the outputs from the sub RCAs, at all frequencies coming out.
    If your gains are set with everything flat (like they should be), then adding a bass boost increases the input signal at a certain range of frequencies. So the amp will be trying to make more power than it can in that range of frequencies at higher volumes (because it should be set to make pretty much max rms power if you set the gains right) and the signal will "clip." This causes distortion, extra heat, and wears down the sub and the amp.
    It may sound like a whole nother sub because you are causing the amp to clip (where it is actually very efficient when clipping) making it louder at certain frequencies (especially if the bass boost freq is around the bass notes of the song) and can make it louder on certain songs.
    Alpine CDA-9833
    Running fully active with US Acoustics 4050 and 4060 Zed built amps
    ID OEM 6.5" mids and Seas 27TAFNC/G aluminum tweeters
    12" Dayton Titanic in 1.2 sealed powered by HS 2.125
    Rich B's Avatar
    Oct 2006
    *under the rainbow*
    6,201
    19 Post(s)
    Re: Bass Boost?
    Quote Originally Posted by XanderMoser View Post
    It may sound like a whole number sub because you are causing the amp to clip (where it is actually very efficient when clipping) making it louder at certain frequencies (especially if the bass boost freq is around the bass notes of the song) and can make it louder on certain songs.
    Yeah, what he said!
    (Very nicely put!)
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Re: Bass Boost?
    Every time someone clips their amps with bass boost, god kills a kitten...
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  9. #9
    luvinthebass's Avatar
    luvinthebass is offline CarAudio.com Elite
    Dec 2004
    Middle of Iowa
    28
    10,447
    Re: Bass Boost?
    very nicely put Xander
  10. #10
    Feb 2006
    Canada,ON
    409
    Re: Bass Boost?
    ya good job, if ur looking for an increase maybe u should look at a larger amp, that way ur wont be running into clipping and can get it louder
    H/U: Panasonic
    Battery: Stock
  11. #11
    Mar 2007
    Wisconsin
    573
    Re: Bass Boost?
    Quote Originally Posted by NewToTheGrounds View Post
    Bingo
    Alpine CDA-9833
  12. #12
    peder25's Avatar
    Jul 2007
    charlotte,nc
    85
    Re: Bass Boost?
    is there a way to tell if you are clipping your amp, or does it always happen when you turn the sub up on you head unit?
  13. #13
    dB-SPL's Avatar
    dB-SPL is offline CarAudio.com Elite
    Aug 2007
    Canandaigua, NY
    837
    Re: Bass Boost?
    Set gains with a DMM.
    -Bill-
    '11 Jeep Patriot
    Head Unit - Pioneer AVH-P3200DVD
    Front - Infinity Kappa's
    Front Amp - Soundstream 200.2
    Subs - 2 Obsidian 15's in 5.5 cubes @ 28Hz
    Sub Amp - Skar 1500
    Stock Electrical
    142.8 @ 41Hz
  14. #14
    Skip01's Avatar
    Skip01 is offline Diggy
    Apr 2006
    Marrero,LA
    7,173
    1 Post(s)
    Re: Bass Boost?
    Find that vid with someone has an oscilloscope and shows the effects of bass boost and how it squares the wave...which is bad...doesnt let you sub cool proper...it may sound louder but its causing damage if not watched
    YOUTUBE VIDZ:
    http://www.youtube.com/user/Skip01
  15. #15
    blazed54's Avatar
    blazed54 is offline Junior Member
    Sep 2007
    Hawaii
    19
    Re: Bass Boost?
    Quote Originally Posted by Rich B View Post
    will it be alright if you set your gains with bass boost on? would this prevent clipping and damage to the sub and still sound good? I ask because i have a bass control knob for my jl 500/1 and unfortunately it works by increasing/decreasing bass boost. thx.
