Results 1 to 6 of 6
Reload Thread: Speaker/Amp Setup Advice
    Viti's Avatar
    Viti is offline Junior Member
    Oct 2007
    Houston, Tx
    Is this a good combination for these speakers?
    2 of these:
    KICKER S15L7
    15" subwoofer with dual 4-ohm voice coils
    Power range: 50-1000 RMS watts
    Peak power: 2000 watts
    Frequency range: 18-100 Hz
    Sensitivity: 88.5 dB
    SoloKon aluminum-treated composite cone with Santoprene surround
    Cast-aluminum basket
    Mounting depth: 8-3/16"
    Sealed box volume: 1.5-6.00 cubic feet
    Ported box volume: 3.0-6.0 cu. ft.
    With this amp pushing both:
    KICKER ZX1500.1
    RMS Power: 1500 Watts x 1 @ 2 Ohm
    RMS Power : 750 Watts x 1 @ 4 Ohm
    Number Of Channels: 1
    Low Frequency response: 20 Hz
    High Frequency Response: 200 Hz
    Signal To Noise Ratio: >95dB
    Active Crossover: 24 db/octave, variable 50Hz-200Hz, Low pass only
    KICKQ Boost: Variable to +18dB
    12db/octave subsonic filter defeatable at 25Hz
    Built In Crossovers: Yes
    Channel Separation: Yes
    Class D Design
    Gain and crossover frequency control
    Protection light indicator
    Mosfet Powered
    Soft Start turn-on
    Protection Circuit
    Remote bass control
    Dimensions: 20" (L) x 2-1/8" (H) x 9-5/8" (D)
    And can I leave the original 4guage wire (maybe 8, I forget) that I'm using to my battery right now? Or do I have to change it for the high wattage? I don't think I'll run over 1000 with that setup though?
    DejaWiz's Avatar
    DejaWiz is online now SQ: don't just hear music
    Aug 2006
    Omaha
    5,170
    1 Post(s)
    Re: Speaker/Amp Setup Advice
    I'd opt for the dual 2 ohm voice coil subs and a ZX2500.1 amp. But if that's the amp you have, then I'd run only one dual 4 ohm voice coil sub and send it the brunt of what the 1500.1 can provide.
    2011 Kia Optima EX
    Factory HU + Speakers
    Planning:
    Front Comps - Blaupunkt Vc660 (active) | Sub - Infinity Kappa 800w IB | 5ch Amp - still deciding
    References
    Bought from: jacobcopeland87, 95bat, alxmlr789, na_rsx
    jblayz1's Avatar
    jblayz1 is offline CarAudio.com Elite
    Aug 2007
    Miami, FL.
    685
    x2
    two 15 L7's would be very sad with 1500 @ 1ohm.
    EDIT: oops i meant 2ohm
    References: 3.5Max6spd, db Dom, theitalianjob76, redcalimp5, karkrazee96, altima98, eric12421, Blazin Bass
    benzmansl65amg's Avatar
    benzmansl65amg is offline CarAudio.com Elite
    May 2007
    Mobile AL
    27
    1,905
    Will that amp hold a one ohm load?
    Head Unit: Kenwood KDC-X996
    Components: Image Dynamics CXS62 V.2
    Amplifier: Rockford Fosgate T600-4
    Subwoofers: Image Dynamics IDQ10v3
    Electrical Upgrades: HO Alt and Big 3
    refs: trunks9_us, calikid, bassjunky, pickup1, bumpin buick, wgsj_fortvalley, holla105, Louisianacrx, pioneerspl1990, N2caraudio.com, terra, canyouhearmatt and many others
    johnson's Avatar
    johnson is offline CarAudio.com Elite
    Aug 2005
    Kansas City, MO
    1,418
    Quote Originally Posted by benzmansl65amg View Post
    Look it up.
    Buyer: Thetalkingshoe, joshs98runner, theCybe, sephiroth619, chornet44, AK SloPok, Looney_Tune, 5.0, iLLest1aLive, scooter2479, SoundBarrier, tapout, jdc753, flatlander4510, etc.
    Stem's Avatar
    Stem is offline n00b Poster
    Oct 2005
    Kauai, HI
    28
    370
    definitely give those more power, but if you cannot i agree get the 2ohm dvc that way you can wire them both to 2ohm load
