Results 1 to 8 of 8
Reload Thread: Speakers wont work now HELP
    jgasmin4219's Avatar
    jgasmin4219 is offline Junior Member
    Sep 2007
    Bay Area
    i installed some after market speakers a few days ago after i finished they worked great. the the next day i installed a sub and amp. now the sub works but the speakers dont. i dont hear a thing. i checked the fuse, im thinking the head unit somehow broke. is that posible that the subs work but not the speakers. if not what is the problem. HELP!!
    reed dollaz's Avatar
    reed dollaz is offline CarAudio.com Veteran
    Apr 2007
    Ocala, FL
    32
    2,750
    Re: Speakers wont work now HELP
    did any wires get disconnected when you hooked up the sub and amp? IE - when your were connecting auxilary and remote wires to your HU, did any speaker wire come loose? or disconnect? id check that first. or, easier, unhook your amp and subs, see if the speakers play. if so, let us know.
    S.O.U.N.D Q.U.A.L.i.T.Y
    HU: Eclipse CD4000
    Front stage amp: Eclipse EA2000
    EQ: Clarion 7 band. EQS
    Front components: Digital Designs DDC6.5
    Rear: Dayton DC 6 1/2 midbass IB
    Rear amp: TBD
    Refs; (SOLD to, Caraudio.com) sgdenny, coolahan, bow125106, killahbean, nismos14
    Boughtfrom; Bjfish, JimJ
    Sep 2007
    Bay Area
    ya i checked all that. i dont think all the speakers wouldnt work with a loose speaker sire i would have heard somethin (correct me if wrong). i reconnected ground, power, and constant wire. i tried running the speakers from different speaker wires didnt work, ran them through the amp heard some noise, n i tried running it without amp n still nothin
    Sep 2007
    Bay Area
    any help?
    Sep 2007
    Bay Area
    help!?!?!
    Sep 2007
    Bay Area
    please help
    kross's Avatar
    kross is offline CarAudio.com Elite
    Jul 2007
    Seattle, WA
    764
    You don't say how you hooked up the sub amp to the headunit. Is the HU stock or aftermarket? Did you use RCA outputs on the HU or did you tie into the rear speakers?
    Also, did you try disconnecting your sub amp, putting it back the way it was when it was working? If so, and still no sound, it's possible you shorted something when installing the sub and amp. If any of the outputs from the HU accidently touched the power wire, that will pretty instantly damage your HU. Did you have the battery disconnected while doing this?
    Sep 2007
    Bay Area
    i have the amp hooked to amp with rca. the head unit is aftermarket. i did try to disconnect the battery everytime, but there might be a time i didnt.
