Results 1 to 3 of 3
Reload Thread: My first experience with Peel & Seal as an FYI......
    RobWiz's Avatar
    RobWiz is offline Member
    Dec 2002
    Redondo Beach, CA
    55
    Just thought I'd give my experience for other people to reference. My '91 Mustang GT is pretty loud between the long tube headers, 2.5" dual exhaust, lopey cam, and the whistling of the 1000cfm supercharger. I planned on doing the doors, floor, and hatch so Dynamat or equivalent would of been expensive to say the least. I went to my local building materials store and they sold me a 100sq ft. roll of aluminum backed "Peel & Seal" for $30 plus tax (they couldn't find their price sheet so they just said $30, I was planning on paying ~$65), not bad at all!
    I've worked with Dynamat before and the Dynamat may of been a bit easier to work with due to the lack of an aluminum backing. But this stuff is very simple to work with also, I noticed I didn't have to heat it as much as Dynamat (I used a hair dryer, worked perfectly). Once this stuff sticks, it's ON, it's very tacky when slightly heated, more so the hotter it gets, but you can't get it to hot or it'll start sticking to the backing when you peel it off. Comapred to a small sheet of Dynamat I had stuck in my hatch the P&S seemed to be a little sturdier even a touch thicker, I believe the aluminum backing had a lot to do with that. Speaking of which I really like the aluminum backing on P&S, I feel it adds a bit extra to the sound proofing aspect. The only drawback is that you really can't lay a large sheet around sharp circular bends (i.e. spare tire well) due to risking air bubbles since the aluminum backing makes it a touch thicker, but you just use smaller sheets/strips on those areas. I didn't use a roller, just my hands and the blunt end of a screwdriver for indentations and corners. Also it has NO odor at all, none, I was surprised
    I finished my hatch last night and it cut the drone from my exhaust considerably....I can't wait to do the floor and doors!
    (3) JL Audio 12W6s <using 1 to save weight>
    (2) Orion XTR 8" midbasses
    6.5" Polk Momo comps.
    Orion XTR 2150
    Orion XTR 800.4
    ifandorbuts's Avatar
    ifandorbuts is offline CarAudio.com Elite
    Jul 2002
    phx
    42
    1,016
    wya to go!
    glad you found a solution to your rattles and loud exhaust
    Damping is the most important part of an install. even if it does not get rid of ALL the rattles, it is still worth the time and money
    let us know how the rest turns out
    ANT
    bootleg's Avatar
    bootleg is offline Got Adire?
    Mar 2002
    San Antonio, TX
    443
    I'll have to look into it, I'm planning to re-do the sound deading in my truck because of the poor quality of www.sounddeadingmaterial.com 's blue stuff. It sagged and dropped off in the summer and even then it was the messiest material I've ever worked with. I got a free roll of Dynamat extreme with a speaker purchase and that stuff is far superior. I curious how to this Peal and Seal will stack up to the D'mat.
    bootleg
    '94 Dodge Ram Std. Cab Sport Red
    100' Sound Deading
    1/0 Power & Ground
    Adire Audio 12" Shiva
    Custom Sealed Fiber-glass Box
    '03 Spring Install:
    Clarion DXZ635MP
    US Acoustics USX2100
    US Acoustics USX2080
    ID & Adire Front Stage
    Adire Audio 12" Shiva Mk. III
