Results 1 to 3 of 3
Reload Thread: Head Units and Amplifier Pre Amp voltages..
    Liamz's Avatar
    Liamz is offline Junior Member
    Mar 2003
    New Zealand
    37
    How important is the pre-amp voltage of a head unit?
    I am considering buying a headunit with a 2.2V pre-amp at 1Kohm impedence.
    My amplifer has a 200mV -2V sensitivity rating,
    with an input impedance of 20K Ohm -
    could this cause an issue with the new h/u?
    My other option is an external Equaliser, which has input
    gain controls, and obviously EQ functionality, which
    my current head unit does not.
    I have been told that if you have a higher head deck pre amp
    voltage, or another device such as a line booster or EQ which
    can do the same thing,
    in between the h/u and amplifier, that the signal into the amp
    will be stronger , and cleaner allowing a stronger and cleaner
    sound output.
    Head Deck (considering buying)- Pioneer DEH-P6550
    EQ (considering buying) - EQ215
    Amplifer - Phoenix Gold B-44 (same as M-44)
    Regards
    Liam
    ws140's Avatar
    ws140 is offline ~`[]D[]][\/]][[]D`~
    Oct 2002
    MA
    33
    671
    The pre amp voltage dosen't make that big of a difference as long as it is 2.0 or more. It is true that the higher pre amp voltage the cleaner the signale will sound, but only to a point. The gian control takes care of the different pre amp voltages coming out of different h/u's. I think you will be fine.
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    1K-ohm preout impedance is kinda high. It makes it hard to drive long RCA cables, and increases the chances of picking up noise. I thought all the Pioneer's were 100 ohms or less.
    The sensitivity of the amp sounds typical.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
