Results 1 to 10 of 10
Reload Thread: 15" box using aero ports
    Rsx_03's Avatar
    Rsx_03 is offline LoW aNd sLoW
    Jan 2006
    miami
    31
    343
    im making a 3.5 cube box using aero ports for my friend
    im using (3) 4" diameter
    i typed it in a calculator and it gave me 25.89" long
    just to make sure i divide that by 3" so its 8.xx"
    also where going to make a plexi glass window to see the subs basket
    what thickness plexiglass do i need?
    mazdakid's Avatar
    mazdakid is online now CarAudio.com Veteran
    Oct 2004
    illnoise
    34
    11,411
    7 Post(s)
    1335 Post(s)
    Re: 15" box using aero ports
    no you dont divide that by 3. its for each port
    06 altima sedan
    Alpine 9887
    Sax 125.4 selenium 6.5s SEAS Prestige 27TAFNC/G
    Dd m4 2 15" fi n2
    traded-pickup1, power-fanatic07, fbi90909
    sold to-superspank, dumple, JoeRa22, sub-FATHER, TrlcKed_OuT, rosrock, dcole18, RaiN, BassAddictJ, tommyk90, MANTI5, Micah_Jones, mrflamboynt, g6ryder, rebelfromva, n8skow, crxbmpn, xr650jkallen, thewes
    germanyt's Avatar
    germanyt is offline CarAudio.com Elite
    Nov 2005
    Ponchatoula, La
    34
    1,670
    3 Post(s)
    347 Post(s)
    did you type it in as a single aero port and your just dividing it by 3? or did you put in the calculator that you are using 3 separate ones? using 3 vice 1 will change your port area 300% which will greatly affect how long they need to be. what are you trying to tune to?
    Check out what I'm up to here:
    https://www.facebook.com/bayousound.net/?ref=aymt_homepage_panel
    Brick and mortar store coming eventually. Website not ready so down until further notice.
    germanyt's Avatar
    Nov 2005
    Ponchatoula, La
    34
    1,670
    3 Post(s)
    347 Post(s)
    after some quick internet math i figure you are looking for 32 hz tuning in which case mazdakid is correct. each of the 3 port should be 25.9 inches long.
    iagrdshaka's Avatar
    iagrdshaka is offline Down with jimmy hats
    May 2005
    Midwest
    19,008
    Quote Originally Posted by mazdakid View Post
    correct
    REFS: Vincent9515, snoopdan, delvryboy, pyro719, teamsubgopoof, coolahan, Toxic Tuan
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    go with 2...they will be shorter...
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Rsx_03's Avatar
    Jan 2006
    miami
    31
    343
    cool thanks ill do 2 ports then .. turns out to 16 inches each.
    to mount it i cut a hole the outer diameter of the aeroport and put a bracket on the back to support the back.
    what glue or adhesive do i use to mount the aeroports.
    mazdakid's Avatar
    Oct 2004
    illnoise
    34
    11,411
    7 Post(s)
    1335 Post(s)
    for the cutout just trace the smaller flare and cut that out
    06 altima sedan
    Alpine 9887
    Dd m4 2 15" fi n2
  9. #9
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    when i built the box for my 15" i didn't support the back of my aero's...although they were a little shorter...about 12" long total. just use some foam gasketing between the box and the flare and screw it down. you may want to duct tape the connections so they don't loosen up...if you glue them, you never get them apart if you ever wanna change the tuning.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  10. #10
    Wkbdkid's Avatar
    Wkbdkid is offline CarAudio.com Veteran
    Mar 2006
    San Diego
    2,834
    3 Post(s)
    If your using a flaerd port you really dont need to brace, doesnt hurt if you do, but when i use a straight pvc i seal the port with silicone and then for support i make a bracket for the pvc to sit on an secure it with silicone.
    Refs: ToxicTuan, LivinLife, BigWill, Bushtree,Chaarlieee,80INCHES, SupaC,Rtillaree,Dalucifer, Dumple91, CRXBMPN, Shallowfu, Calikid, 90accordman, Zeuslicious, IonSQL, Quino, Slowbmw,Twisztdpunisher,
    themommyvan, MSW Danny, Theelfkeeper, Fusion FREAK, Bigtymer2306, keviNxL, WooferCooker, Team H & K, Luv2Shroom
