Results 1 to 5 of 5
Reload Thread: hooking up amp to stock hu
    91lacdeville's Avatar
    91lacdeville is offline Senior VIP Member
    Jan 2003
    CT
    27
    481
    I am about to hook up an amp for my friend to his stock hu but i dont know what to connect the remote lead turn on to
    ChefJoe's Avatar
    ChefJoe is offline Senior VIP Member
    Dec 2002
    Columbus, OH
    33
    267
    Antenna wire on the factory wiring... what car, what's installdr.com say?
    97 VW Jetta - building a system from parts in my old 85 Jetta
    HU: Pioneer P740MP with 12 disc changer
    Front: 3.5" JBL GTO302s in dash
    5.25" Cerwin Vega Vega Series 502s in door
    Amped: US Acoustics USX-2050 @ 2 ohm
    Rear: Stock components
    Sub: Single 12" Vega 124 in a cheap bandpass box
    Sub Amp:US Acoustics USX-2150 bridged
    Jan 2003
    CT
    27
    481
    It is for a 1996 volvo 850 gt. Where would this wire be found. Is it on the rear of the head unit or could i connect it to the wire going to the actual antenna because i dont know how to remove the hu since i don't have the haynes manual for this car.
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    well i know its in the back of the HU usually, i guess you could hook it up elsewhere if u find it. I beleive its generally yellow?
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    ChefJoe's Avatar
    Dec 2002
    Columbus, OH
    33
    267
    Fire up netscape (IE doesn't work with installdr.com) and look at the three pdf files for installing yourself volvo type cars. See what's appicable to your installation. Does your volvo have one of those mini roof mount antennas? When you do get back there, what's the connector look like? This really is a thing to find out about your specific car... an internet forum or search for wiring harness for your type of car would help a bunch.
    If it's just the turn on lead, you can connect it to any switched power source (like in the fusebox) and the amp will be on whenever the car's running.... which is better than always on and better than hooking a switch up and wiring into the battery and remembering to turn it off.
    http://www.installdr.com/InstallDocs...PDF/865001.pdf
