Results 1 to 9 of 9
Reload Thread: Amp to hot. shuts off. pop noises.
    YoungBuk's Avatar
    YoungBuk is offline Member
    Feb 2006
    chicago
    97
    hey, i just got a 12jlw3v2. got a cheap visonik 400 x1 2 ohm mono amp. its all wired at 2 ohm. turn it on theres pop noises also when turning off. and the amp is so hot that u cant hold ur hand there for 5 seconds(is it normal). and the amp will shut off if i turn the volume over 20. the amp gain is half way so is the hrtz.
    jeffs42885's Avatar
    jeffs42885 is offline Experienced Noob
    Oct 2004
    Scranton, PA
    33
    1,093
    Re: Amp to hot. shuts off. pop noises.
    Quote Originally Posted by YoungBuk View Post
    use a multi meter to set the gain, just because its half way doesnt mean that your not potentially ****ing somthing up..i usually keep my sub crossovers at 120hz. and what config are the w3's i didnt think they made them in dual 2 or single 4 thought only dual 4
    09 G8 GT- Show and Go, System coming spring 2012
    11 Scion TC - Daily, 10W7
    Grinder1989's Avatar
    Grinder1989 is offline Sundown Audio Dealer
    Jan 2007
    Akron, OH
    5,730
    do your wiring correctly and make sure its not grounded out or anything is backwards. If that doesn't fix it, toss your amp and buy a new amp, something worthwhile instead of that garbage you have now.
    North Coast Improvements, Mobile Audio Division. Sundown Audio Dealer Akron, OH. Need BNIB audio? PM me for details.
    By: N.G.U Graphics
    blackbonnie's Avatar
    blackbonnie is offline The Revolution
    Jan 2007
    Grand Rapids, MI
    10,146
    sounds like you have a bad ground with the popping issue, and with it getting hot, what impedence is your sub wired to, and what size power and ground wire are you running. you may be working your amp to hard, and striving it for current, or to low of an impedence
    HU - Pioneer 800prs
    Mids - Peerless HDS nomex 6.5's
    Highs - Seas Prestige Alumi-domes
    Front Stage Amp - Sundown 100.4D
    Sub - SA-12
    Sub Amp - Saz-1000D
    Wire - Knukonceptz, Kicker Hyperflex
    Blackbonnie References/Feedback
    StealthKill's Avatar
    StealthKill is offline is hungry
    Sep 2006
    OK
    1,578
    Quote Originally Posted by blackbonnie View Post
    Use that DMM to check your ground.
    CRAZYCORNUTS18's Avatar
    CRAZYCORNUTS18 is offline Registered User
    Mar 2007
    PAT
    29
    1,878
    yea i think you got it wired 1 ohm instead 2 ohm like you think you do
    YoungBuk's Avatar
    Feb 2006
    chicago
    97
    hey, i think the popping noise is definitly form the ground wire cuz it was like that with my old system. im probably going to buy a new amp. since mysub is dual 4 ohm, would it be better to buy a 600 watt 2 ohm mono or a 600 wat 2 channel 4 ohm? thanks for the help guys.
    Jan 2007
    Grand Rapids, MI
    10,146
    either would work, but i would buy a mono personally
    HU - Pioneer 800prs
    Sub - SA-12
    Sub Amp - Saz-1000D
  9. #9
    fwb_1234's Avatar
    fwb_1234 is offline CarAudio.com Elite
    Jan 2007
    Greenville, SC
    1,902
    I agree.
    Edit: It gives you more options in the future, if you decide to change sub, or it blows, or whatever.
    Refs: SeanDub, jblanford, 95BlackGA, Flipx99, BiaBia
