Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Can you bridge a HU?
    chase297's Avatar
    chase297 is offline Member
    Dec 2002
    West Hartford, CT
    140
    I know you can bridge most for channel amps but is it possible to do it on a HU. Cause I have a 7893 and Im gonna be running components off an external amp, so I wanted to know if I could send a little more power to the rears. Thanks
    abcdefg's Avatar
    abcdefg is offline CarAudio.com Veteran
    Oct 2002
    Clarksville, Tn
    30
    2,330
    bridging a h/u is not recommended...
    Pioneer Premier DEH-660
    1 12inch ED k
    2 12inch RE HC's
    Hifonics brutus 1000d
    infinity kappa 6 1/2 components
    polk 5 1/4's
    US Acoustics USX2080
    sony cd player-4sale
    jensen 4's- 4sale
    check this out guys:
    http://www.sounddomain.com/id/tumultgoboomboom
    Aim= wrde2005
    Email= wrde333@aol.com
    Aol instant message= wrde333
    chase297's Avatar
    Dec 2002
    West Hartford, CT
    140
    how come just puts to much stress on it?
    abcdefg's Avatar
    Oct 2002
    Clarksville, Tn
    30
    2,330
    yea i think that it can mess up the internal mp on the h/u
    1 12inch ED k
    2 12inch RE HC's
    polk 5 1/4's
    jensen 4's- 4sale
    Aim= wrde2005
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Your internal amp wasn't meant to handle anything more than a 4 ohm load...just like some amps are only 2 ohm stable, its not recommended to run anything with a lower impedance on it...
    Moocow16's Avatar
    Moocow16 is offline Master of Puppets
    Aug 2002
    Detroit
    31
    1,482
    3 Post(s)
    i run 2 channel's at 8 ohm, the other 2 at 4 ohm, nothing's happened yet, and i hope nothing will happen until i get my new 4-channel amp.
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    8 ohms is higher than 4 ohms...it can probably handle that.
    f150_on_32s's Avatar
    f150_on_32s is offline Senior VIP Member
    Dec 2002
    Thibodaux, La
    265
    ohms
    if you run your headunit into an 8 ohm load. your cd player will have to work harder to force power through the increased resistance. if you play you hu at high volume you will run into heat problems caused by the over-exertion.
  9. #9
    Moocow16's Avatar
    Aug 2002
    Detroit
    31
    1,482
    3 Post(s)
    well, when i get a job, i'll get a nice Helix 4 channel and get rid of the 3 1/2"s in the dash, since they're basically useless.
  10. #10
    Rockman's Avatar
    Rockman is offline CarAudio.com Elite
    Nov 2002
    topeka
    518
    Re: ohms
    Um thats actually not correct. Since the load impeadance is higher the radio cannot "force" more power to the speakers. It simply will not produce as much power into a higher impeadance load.. If anything the radio will run cooler at higher volume setting since the amplifier cannot produce as much power into an 8ohm load..
    Car 99 Toyota Solara SLE V6
    HU Clarion DXZ835MP
    Front Speakers Infinity 6 1/2 Kappas
    Front Amp Crutchfield CR4X50
    Subs Kicker 12L7's
    Harrison Fmods
    Sub Amp PPI PC 2600's
  11. #11
    Dec 2002
    Thibodaux, La
    265
    i did it with a pioneer
    i had a pioneer hu and i had an 8 ohm load on each channel. after about 15 mins of over 25 volume, it melted the glue that held the custom cd label on my cd. i had to send it off because the label meltedand got stuck inside. pioneer told me it was because of the ohm load i was running. may be they were lieing
  12. #12
    avistar23's Avatar
    avistar23 is offline www.SoundhertZ.com <---
    Dec 2001
    Nassau Bahamas
    29
    2,723
    it probably was .....i wouldnt think that would happen though.
    C6ANU
    Eclipse H/U
    Profile j 600.4 bridged to 2 chanells
    Adire Koda 6.1
    Profile ca1200
    Kove Audio Armegedon 12
    AudioControl Matrix
    Soon to come:
    Audio control 24xs
    Audio control EQL
  13. #13
    Rockman's Avatar
    Nov 2002
    topeka
    518
    Less impeadance = more power = more heat. More impeadance =less power=less heat.
    It wasn't because of an 8ohm load, that is actually easier on the output devices..
    HU Clarion DXZ835MP
    Subs Kicker 12L7's
    Harrison Fmods
  14. #14
    eengrms's Avatar
    eengrms is offline CarAudio.com Elite
    Feb 2003
    USA
    41
    556
    I hate to burst everyone's bubble, but impedence has little to do with heat. Heat is generated by current, or a by-product to state it correctly. If you have a constant voltage and constant impedence (or resistance) and a varying current then you will generate heat- regardless of what level the impedence is at. f150_on_32s- your deck melted because you played it too loud for too long, and it was probably bound to happen anyway. One correlation impedence has to current is when the impedence varies. But for this to occur the current would have to be constant, which it rarely ever is. So basically it's just too simple to say: "Less impeadance = more power = more heat. More impeadance =less power=less heat." without taking into account the status of the current in the system, as well as the direction the current is flowing. Less mipedence could mean more heat, it could mean less heat. What the change in impedence does do is make hard for the device to regulate the voltage, hence amps stating their stability at certain ohm levels.
  15. #15
    Rockman's Avatar
    Nov 2002
    topeka
    518
    But for the most part as you lower the impeadance especially with amplifiers more current will flow. So your saying if you run a 2 ohm load vs an 8 ohm and amplifier will not produce more heat. Any decent amp is going to produce more power at 2ohms than at 8ohms. How does it do that , by producing more current. More current is going to make more heat. How did you make more current, by lowering the impeadance. Its general statement yes, but it is also accurate.
    HU Clarion DXZ835MP
    Subs Kicker 12L7's
    Harrison Fmods
