Results 1 to 2 of 2
Reload Thread: What to set amp crossover at using passive crossover?
    nrgy's Avatar
    nrgy is offline Member
    Nov 2002
    USA
    100
    What should I set the crossover settings on the amplifier at if I am using a passive crossover with my components? I can either select High Pass, Low Pass, or Flat. This is a 4 channel amplifier, and I will be bi-amping the crossover. They are three way components. I'm thinking it might be best just to set it to Flat and let the passive crossovers handle everything. Suggestions?
    Now Playing:
    JBL P80.4
    Boston Acoustics Pro Series 6.53 Components
    Tsunami Silencer Sound Deadning
    Waiting for Installation:
    Boston Acoustics 8.5LF Pro Series Subwoofer
    Coming Soon:
    JBL 300.1
    IowaBoomer's Avatar
    IowaBoomer is offline Member
    Dec 2001
    Walnut, IA
    97
    If you set it the same on both, then you will effectivly be double the cutoff ability.
    For example, 12db per octave would become 24, etc.
    If you want a clean break, then thats what I would do. Otherwise, let the passive handle it.
    New and Improved system:
    JL12W7
    Alpine 7893
    JL 500/1
    Big *** Vented Box.
    Eclipse 4'' 2 ways
    All adding up to a new bigger number...can't wait for the new season.
