Results 1 to 11 of 11
Reload Thread: Need recommendation on system
    Arni's Avatar
    Arni is offline Junior Member
    Jan 2003
    Iceland
    Icon32 Need recommendation on system
    Hi all of you
    I am new into this and find things rather confusing when it comes into consiferating power combination for each unit.
    I got a Nissan king cab pick and want to install 2 speakers (2 or 2 way) in the front doors and a sub to have behind the back seed.
    I like to listen to music very loud but with without the loss of quality.
    Now, I know ofcours that recommendation of type of speakers and amps will vary but hardly the numbers (rms watts) tha I need to reach what I am looking for.
    Up to what point can or below what should I not go in regard to reach or keep the kind of power output I need to be able to play a high levels keeping quality?
    What are crossovers?
    Regards
    Árni
    arnistefanarnason.com
    Dec 2001
    Kent State/Mentor Ohio
    868
    You said a mouth full there.
    First thing to remember is that its not the driver that always makes the difference it is the quality of the instalation.
    One of the major things to remember...boxes are to be designed around a driver. Expecially in an SQ situation...prefab boxes will cause you nothing but heartache.
    There are ceratain name brands that you should stay away from...made purley for SPL. Others are just crap.
    Also, making sure you have an efficent but clean sounding amp is critical
    All things you should realize
    I dont think any of us can really press a product unless we know your price range
    Crossovers over all limit out frequencys that go to a driver...
    Heres an example.. Your head unit (unless it has built in cut offs) will send your sub amp the full spectrem of signals.. A sub woofer is not meant to be played over 120 hz (...thats high for a lot of drivers even) and if you do not set your cross over on your ampto limit it under that it will send the full signal to your driver and basically it will sound like crap.
    That also works on high end to send high notes to the tweets and midrange to the mids
    Arni's Avatar
    Jan 2003
    Iceland
    "First thing to remember is that its not the driver that always makes the difference it is the quality of the instalation"
    What exactly do you mean by this?
    "boxes are to be designed around a driver"
    do u mean that I should first consider the ampl then select the speakers or opposite?
    "There are ceratain name brands that you should stay away from"
    I certainly would be interestend in knowing more here as I live in Iceland were there is a very limited number of brands to select from. I am looking at stuff from the following two resellert at www.sm.is and www.aukaraf.is, can you visit their site and let me know what brand names that they sell I should try to stay with? pls
    "Also, making sure you have an efficent but clean sounding amp is critical"
    How can I make sure that I select such an amp? What brands are preferable?
    "Crossovers over all limit out frequencys that go to a driver...
    Heres an example.. Your head unit (unless it has built in cut offs) will send your sub amp the full spectrem of signals.. A sub woofer is not meant to be played over 120 hz (...thats high for a lot of drivers even) and if you do not set your cross over on your ampto limit it under that it will send the full signal to your driver and basically it will sound like crap."
    Are you saying that if the sub amp does not have a build in crossover to control the frequency that I should get myself a seperata crossover that I connect between head unit and sub amp to control the frequency going to the sub amp?
    Thank you if you find time to reply to this.
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    Basically, you can have $1000's in equipment, but have a really ghetto/crappy install, and make everything sound horribly wrong
    What he said is that certain subs need certain boxes...and the boxes are determined by the sub being used. I would choose the sub first, then look at amps.
    Generally, you want to stay away from Pyle, Pyramid, Rockwood/Kenford/etc...we can help you further with brands if you need to. I always suggest listening to your equipment before purchasing so you know what you are getting into. Especially speakers...with subs it isnt too as you can vary the box
    This depends on what sub you are getting and your price range
    Pretty much
    If you havent already, check out the following:
    www.edesignaudio.com
    www.respl.com
    www.imagedynamicsusa.com
    www.adireaudio.com
    www.mtxaudio.com
    www.kicker.com
    www.rockfordfosgate.com
    www.eclipse-web.com
    www.bostonacoustics.com
    www.mbquart.com
    www.mmatsproseries.com
    ETC.
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    Arni's Avatar
    Jan 2003
    Iceland
    "Basically, you can have $1000's in equipment, but have a really ghetto/crappy install, and make everything sound horribly wrong "
    Well what things are there to be aware off when one installs a audio system into a car.
    Wiring appears to be straight forward, placement of speakers go into the doors, the head unit has it´s secure place and power......etc, are there key factors appart from this to look into to improve sound quality????????????
    "What he said is that certain subs need certain boxes"
    I am not getting the picture here, what do you mean by boxes? The box the speaker is build into? Sorry I am not joking with this question but if I am understanding this correctly can you give me an example of difference of boxes via speakers.
    "we can help you further with brands if you need to"
    I do! I have access to, Kenwood, Jbl, Rockford, Lighting audio, Clarion, AudioControl, Genesis(UK)
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    The correct box for the sub is critical. Also placement of speakers for imaging purposes is key. Crossovers and EQ's need to be set properly.
    Subwoofer "X" may sound best in a box that is either 2.5 ft^3 sealed, or 3.8 ft^3 ported @ 35hz. Subwoofer "Y" may sound best in a box that is either 1.2 ft^3 sealed, or a 6.8 ft^3 ported @ 28hz.
    Kenwood is decent, JBL would be good in terms of your amps, Rockford is alright for amps/subs, speakers are nice, Clarion makes fairly nice head units, Lightning Audio is generally alright, AudioControl is nice for EQ's and such
    Hope I helped clear some things up.
    - Steve
    Moderator
    2007 Chrysler 300C
    Arni's Avatar
    Jan 2003
    Iceland
    what about mtx in reg of speakers and amps
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    MTX makes fairly nice amps, in my opinion. I own some of their speakers and I am impressed with the sound quality of their 6.5" components...I am currently running them in my Camaro. Their subs are alright for beginners...the 6000 series are very common in regular cab trucks, since they have a very shallow mounting depth. I would say their subs are more towards SPL, rather than SQ. Dont look at the Road Thunder stuff...just the Series 6000/8000.
    - Steve
    Moderator
    2007 Chrysler 300C
  9. #9
    Mac11's Avatar
    Mac11 is offline MacGyver
    Dec 2002
    Outside Chicago
    34
    1,115
    i dont have any experience with TMX speakers but i have owned a couple MTX amps and they are nice.
    "I'm craving carrots but all I have are these cookies!" -Rdub
    "HEY!! I stopped sellin pot after my first senior year!" -SD
  10. #10
    Arni's Avatar
    Jan 2003
    Iceland
    Got one more question for the time being, in the front doors of my pick up there is a thick plastic cover behind the front cover. The plastic is designed to go behind the rear part of the speakers so that there is only a small whole for the wires to go through. Will removing the plastic from behind the speakers and by this opening up the whole inner space of the door improve or do nothing for the the sound quality ?
  11. #11
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    35
    1,509
    it would probably be better to leave it....may give you a little more midbass...
