anyone ever work w/ one of these, if so how easy are the speakers to get to......one speaker is blown so i want just to replace them, nothing too fancy![]()
I drive an '01 The only hard part is the trim for the inside door handle. I cracked mine because i've had them on/off more times than i can remember. I think the trick is to pry on the side nearest the rear of the truck between the lock indicator and the trim, then the same spot, but on the bottom. The side near the door hinges has a hook on it. It's been a while, but i think that's right
The panel goes on very well. I have zero vibrations.
Worked on one about a month ago. Very simple and straight forward. The only problem I had was unclipping the wires but I have huge hands ha.
System:
Deck:Alpine 9835
Components: JL xr
Comp. Amp: Profile AP400
Substage: Two assasin 8s
Sub Amp: Orion1200D
Refs: Chevyaudio,Fi car audio,Mlstrass
Bookmarks
