Results 1 to 6 of 6
Reload Thread: Preamp voltage?
    Dec 2001
    Kent State/Mentor Ohio
    868
    Yes and No
    I mean it depends on your amp.
    By giving it more siginal it doesnt have to work as hard and thus can create a cleaner sounding signal
    Now between say .5 and 5v your going to notice a whole lot of difference...unless your amp/drivers are crappy
    kingpin_jeffie's Avatar
    kingpin_jeffie is offline i need a vacation...
    Mar 2002
    Erie, PA
    1,259
    if the decks in question are relatively equal in options and in price go with the 5V
    if they arent so equal its up to you to decide but keep in mind 5V is alot cleaner signal than 2V. cleaner is better
    Eclipse 8445|Alpine Type X 137r|Diamond D5 300.2/1200.1|ID 10v.3|
    Refs: KARLEON, sephiroth619, SiX, Showrides, angrytrucker78, davidfre21, Relax, Slammed
    He who laughs last is usually the slowest...
    Spddracer's Avatar
    Spddracer is offline Sounds Goooooood
    Mar 2002
    Ohio
    50
    1,345
    15
    I could not tell the diff in my 8 volt Eclipse pre outs and my 2 volt Alpine preouts except I need to adjust my gains differently , The 8 volt actually made my amps sound worse , To much signal I think , Couldnt turn my amps down far enough , Thats what a gain adjustment is for !
    1990 300ZX Stage IV Twin Turbo
    Pioneer Premier P940MP
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    PEOPLE ON WELFARE DEPEND ON YOU"
    Savant's Avatar
    Savant is offline Duke of DOH!
    Dec 2002
    Colorado Springs, CO
    48
    1,347
    Originally posted by shrinkydinx
    8v? is that 'balanced'? are all amps compatible with 'balanced' preouts?
    I'd have to agree.. most amps (that I've seen) only want at most 6 volt.. so 8 is more than they like and the gains won't let you drop far enough to keep the system balanced.. and I'd have to immagine that too much input voltage causes clipping much earlier in the amplifying process *shrug*..
    (1) Alpine CDA 7892 HU ($214)
    (2) 12" Pioneer Premier 1241DVCs in sealed MDF box (gonna glass them eventually) ($69 each)
    ->removing.. ->(2) 10" Pioneer Premier 1041DVC's in sealed MDF box (gonna glass them eventually) ($59 each)
    (2) Lanzar Vibe248 1200 watt 2 chnl amps ($119 each)
    It's bump'n GOOD!
    You can lead a horse to water but you can't make a moron understand...
    Savant's Avatar
    Dec 2002
    48
    1,347
    Originally posted by Jmac
    That's unbalanced It's 16 volts balanced
    You jerkin' chains here Macster?
    Really, is 16 volts common for inputs on amps? I really did think it was pretty low for most amps..
    It's bump'n GOOD!
    ryan_feine's Avatar
    ryan_feine is offline Member
    Feb 2003
    Rushford, MN
    33
    86
    their right most amps dont like voltages that high jls new amps with rips have a switch for high or low voltage selection
    Ryan Feine
    [email protected](MSN messenger)
    Clarion DX515 headunit
    MB Quart 6x9s
    MTX Thunder4122
    2 HE2 10"s
    2 JL Audio 500.1s
    not installed
    MB Quart 6.5s
    Alpine 6.5s
