Results 1 to 5 of 5
Reload Thread: What do I need?
    Xowner's Avatar
    Xowner is offline Junior Member
    Jan 2003
    Fayettevile, NC
    41
    15
    What do I need?
    I just had a new Sony headunit installed in my Nissan Xterra and there's a slight probelm. The volume only goes half-way before maxing out. The installer said I need some special " wire " or connection piece ($60) to fix it and this problem is due to the make of the car being Nissan. Any other HU would have the same result with the volume. If I was to install my amp and sub right now when adjusting the sub through the HU the other speakers would adjust with it. At the time the installer didn't know the name of the part I need but he did know it would cost $60 for the part and $20 labor.
    Any idea what part I need?
    Let it be clean and clear
    abcdefg's Avatar
    abcdefg is offline CarAudio.com Veteran
    Oct 2002
    Clarksville, Tn
    31
    2,330
    where did u get it installed at???
    Pioneer Premier DEH-660
    1 12inch ED k
    2 12inch RE HC's
    Hifonics brutus 1000d
    infinity kappa 6 1/2 components
    polk 5 1/4's
    US Acoustics USX2080
    sony cd player-4sale
    jensen 4's- 4sale
    check this out guys:
    http://www.sounddomain.com/id/tumultgoboomboom
    Aim= wrde2005
    Email= [email protected]
    Aol instant message= wrde333
    Xowner's Avatar
    Jan 2003
    Fayettevile, NC
    41
    15
    I got it installed at a local car audio shop that is pretty well known ( Rudy's Car Audio ).
    The installer pointed that Nissan's have this problem due to the stereo's that they put in them. My factory HU was a 6-disc indash changer that had steering wheel controls. I knew that the steering wheel controls are lost with the aftermarket HU but that was no big deal.
    Xowner's Avatar
    Jan 2003
    Fayettevile, NC
    41
    15
    My HU has front, rear, and sub preouts. Which would I use? Remember, I'm adding a sub amp and will add a mids/highs amp in the future. Thanks.
    Dec 2001
    Kent State/Mentor Ohio
    868
    Well I was thinking about it...and why get a line converter if you already have RCA outs...
    Just go to radio shack and get some rca heads
    Put one on each channel of your front spearkers and connect them to your front RCA outs
    If it works and sounds as it shoould...do the same for the back (if your having the problem back there as well)
    IF it doesnt work for whatever reason they cost you probably $1.50
    The box thing would only be needed for a headunit with no preamps out
    I dont even remember being on drugs last night...must have been good though
    This worked for my gf's nissan...but im not not totaly sure if it will for you. Though I assume it's the same problem
