Results 1 to 5 of 5
Reload Thread: Running subs in parallel?
    Justinh722's Avatar
    Justinh722 is offline Senior VIP Member
    Nov 2002
    Mason City, Iowa
    33
    213
    5 Post(s)
    If i were to wire my subs in parallel from 4 ohm to 2, and if my amp was 2 ohm stable, would running my subs in parallel make them hit harder?
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Running subs in parallel?
    if you play with the wires, that's raising the output of your subs...
    i don't think anysort of wiring would raise the handling capacity of a speaker... your AMPS would hit harder, I should think....
    Ok, be easy on me, this is all just my 2 cents....
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Savant's Avatar
    Savant is offline Duke of DOH!
    Dec 2002
    Colorado Springs, CO
    48
    1,347
    As I understand it.. your amp puts out more power at 2 ohm than at 4 (in general, not all amps do this).. but it has to be 2 ohm stable or it will shutdown or melt.. since you get more power from 2 ohm, your subs will be getting more power (and hitting harder, unless they blow)..
    The amp will run hotter as well.. just so you know..
    (1) Alpine CDA 7892 HU ($214)
    (2) 12" Pioneer Premier 1241DVCs in sealed MDF box (gonna glass them eventually) ($69 each)
    ->removing.. ->(2) 10" Pioneer Premier 1041DVC's in sealed MDF box (gonna glass them eventually) ($59 each)
    (2) Lanzar Vibe248 1200 watt 2 chnl amps ($119 each)
    It's bump'n GOOD!
    You can lead a horse to water but you can't make a moron understand...
    Justinh722's Avatar
    Nov 2002
    Mason City, Iowa
    33
    213
    5 Post(s)
    so i have a rockford 250.2 and it says its 62.5 watts at 4 ohms 125 watts at 2 ohms does this mean its 2 ohm stable if it says how much power it is running at 2 ohms?
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    yes, it is 2 ohm (stereo) stable...
    if you ran 2 channels (i.e. two speakers linked to the left and right terminals), that'd be 125watts to EACH channel...
    hmm, if it was 2 ohm mono stable, then you'd have about 250watts in one channel...
    tell you what, why not got o RF's webiste, go to RFtech and library archive...
    get your user's manual... it's stated specifically what yor amps can handle...
    That's how I found ALL my RF product manuals again~
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
