Results 1 to 4 of 4
Reload Thread: Best way to make a "rabbit" on MDF cut out for Plexi window with no router??
    RobWiz's Avatar
    RobWiz is offline Member
    Dec 2002
    Redondo Beach, CA
    55
    Icon32 Best way to make a "rabbit" on MDF cut out for Plexi window with no router??
    I'm going to be making a "step" (a rabbit I believe it's called) in the cut outs of my MDF floor in the hatch for Plexi windows. I'm assuming a router is the proper tool for the job. I don't have access to a router so what's the next best tool/way to make the step to lay my Plexi in??
    Thanks,
    Rob
    (3) JL Audio 12W6s <using 1 to save weight>
    (2) Orion XTR 8" midbasses
    6.5" Polk Momo comps.
    Orion XTR 2150
    Orion XTR 800.4
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    4,209
    If you don't have a router I'm assuming you don't have a radial arm saw or table saw...How about a regular circular saw? You can just cut successive passes with the blade set really shallow and eventually you should get where you want to go.
    '99 Taurus SHO (welded)
    • HU: Stock - Scosche SLC-4
    • Comps: Lanzar Opti6c w/Opti400x4d
    • Rear fill: Stock
    • Sub: Lanzar Opti1232D w/Opti1000.1d
    ebay feedback: http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=en_force_r&ftab =AllFeedback
    Heresy's Avatar
    Heresy is offline Going Against the Grain
    Dec 2001
    Arizona
    29
    1,221
    A table saw with a dado would work very well if you don't have a router. If you don't have access to one there is always the extremely inprecise method of using a a chisel which I have done before when I was too lazy to set up anything else.
    The handheld circular saw would work but you better have a steady hand or at least a makeshift fence to guide off of. I have had too many bad experiences with those saws to recommend them unless you absolutly must.
    Igitur qui desiderat pacem, praeparet bellum -- Vegetius
    "I told her about my conversation three years ago with the political leader of Islamic Jihad in Gaza. "What's the difference between suicide, which the Koran condemns, and martyrdom?" I asked. "Suicide," he replied, "is done out of despair. But remember: most of our martyrs today were very successful in their earthly lives." In short, there was a future to live for--and they detonated it anyway."
    Spddracer's Avatar
    Spddracer is offline Sounds Goooooood
    Mar 2002
    Ohio
    45
    1,345
    15
    How bout just using another piece of wood on top same thicknes as the plexi , Make it a little bigger than your cut out of the original floor(same size cutout as the plexi) and put it on top of the original floor and then you glass shall fit perfect !
    1990 300ZX Stage IV Twin Turbo
    Pioneer Premier P940MP
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    PEOPLE ON WELFARE DEPEND ON YOU"
