+ Reply to Thread
Page 43 of 56 FirstFirst ... 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 LastLast
Results 631 to 645 of 827
Reload Thread: Carputer 101
  1. #631
    spoonraker's Avatar
    spoonraker is offline CarAudio.com Elite
    Sep 2006
    Lincoln, NE
    1,249
    Re: Carputer 101
    Are USB cards supported by kX project drivers at all?
    References : chaunb3400, Team H&K, diminishedpower, pickup1, sublime06, sporty_drew, JRock10, Jando86, sundownz
  2. #632
    Megalomaniac's Avatar
    Megalomaniac is offline Mr.SQ
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    noise issues are minimal with the card. I hope you cleaned up your install now that you are back from the trip
    Quote Originally Posted by spoonraker View Post
    dono ?
    Quote Originally Posted by Second Skin Rep View Post
    so in closing...
    Don't punch babies..
    ANT
    www.secondskinaudio.com
  3. #633
    spoonraker's Avatar
    Sep 2006
    Lincoln, NE
    1,249
    Re: Carputer 101
    my internal PCI card is 100% noise free once it turns on, but when the computer is booting up there is all kinds of noise...
  4. #634
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    even if you RS?
    so in closing...
    ANT
  5. #635
    spoonraker's Avatar
    Sep 2006
    Lincoln, NE
    1,249
    Re: Carputer 101
    I have my amps and my PC triggered by the same remote wire. So if I just get in and turn the key, the amps turn on immediately and there is a ton of noise...then once the computer resumes from hibernation and the sound card is turned on the noise abruptly stops.
    I usually don't notice it because I remote start the pc so its ready to go when I jump in
  6. #636
    Ruffy's Avatar
    Ruffy is offline Death to the salad eaters
    Apr 2006
    Las Vegas, NV
    32
    382
    19 Post(s)
    Re: Carputer 101
    no. But many of the better usb solutions support Aiso
    _______________
    For Sale, PM me
    Comps : Rainbow Audio SLC 265
    Subs : Diamond Audio D6 12" Subs X2
    Amp 1 : Hifonics ZXi 6006 AB Amp
    Amp 2 : Hifonics BXi 1606 D Amp
  7. #637
    bland's Avatar
    bland is offline Member
    Aug 2007
    canada
    146
    Re: Carputer 101
    Install is cleaned up a bit, but not to much. With the glove box closed you don't see it.
    I only had it open because I was concerned with heat issues, which others were having, and didn't want it to go down on a 12+ hour road trip. I've been lucky and the heat has never been a issue.
  8. #638
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    Quote Originally Posted by bland View Post
    i suggest you relocate it boss. clean up them wires and retain your glove compartment for your gloves
    so in closing...
    ANT
  9. #639
    bland's Avatar
    Aug 2007
    canada
    146
    Re: Carputer 101
    No need. It's been in for almost a year now, and that includes last winter and this summer.
    I'm Canadian eh! so it has seen extreme cold, and the heat of this summer and no ill effects. It did get really warm to the touch on my longer road trips this summer, but when I verified the temps of the motherboard and the cpu it was still 30 - 40 degrees below it's danger point.
  10. #640
    viziers's Avatar
    viziers is offline Member
    Jul 2007
    North Carolina
    91
    Re: Carputer 101
    Viziers, those components look pretty good. The only thing I worry about is the monitor, it says it's a 7'' touchscreen, but there is a large button panel on the side. So either the screen is much smaller than most 7'' monitors, or the unit its self is about an inch wider than most which could make installation more difficult.
    Oh and I always thought it would be fun to have a fingerprint scanner start the car...you should do it since you have one.
    How would this be for a TS?
    http://dynamixcomputers.com/dynamix_...n_monitor.html - TS monitor
  11. #641
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    i meant relocate it for more cosmetic self gratification feeling
    Quote Originally Posted by viziers View Post
    i suggest you either get a Lilliput or a Xenarc so you get extra "tech-support" from everyone
    so in closing...
    ANT
  12. #642
    viziers's Avatar
    Jul 2007
    North Carolina
    91
    Re: Carputer 101
    Can the Alpine h-701 be used without the Alpine RUX - C701? If so how would you go about doing it with just using the CarPuter and NO HU?
    viziers
  13. #643
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    viziers
    it can be. but it requires a HU then. the c701 is just a controller all it does is control the h701. you dont have to have the controller plugged in all the time. my friend what he does is plug the controller in and tunes everything. once everything is set he takes the controller out.
    so in closing...
    ANT
  14. #644
    viziers's Avatar
    Jul 2007
    North Carolina
    91
    Re: Carputer 101
    Quote Originally Posted by Megalomaniac View Post
    Mega,
    Do you know of any other options for a processor that i can use without a HU?
  15. #645
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    The Drive 30 can be used using the carputer and a serial cable, im planning to get that
    so in closing...
    ANT
+ Reply to Thread
