+ Reply to Thread
Page 42 of 56 FirstFirst ... 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 LastLast
Results 616 to 630 of 827
Reload Thread: Carputer 101
  1. #616
    jadon087's Avatar
    jadon087 is offline The Snowman
    Jan 2007
    Columbia,Sc
    25
    2,476
    Re: Carputer 101
    got any more pics also?
    refs:Ca.com:pboulos(x2),jeepintn(x2),flipx99,altima98,h eyduude888,lmllopez, brchd, 22mountaineer(x2),NhustlaR(x2), Buck, crownvicon4's,quakercountry,cloak(x2),Twank06"GTO, fasfocus, WilsSebring
    sounddomain:banbury,GmcTruckman
    roe:jdiddy, Team_Havoc_Spl, grandprixgtx
    l
  2. #617
    viziers's Avatar
    viziers is offline Member
    Jul 2007
    North Carolina
    91
    Re: Carputer 101
    Hey Mega,
    Heres one for ya maybe two for ya..
    1. By having a carputer is there a way to retain the MFSW (multi function steering wheel) controls and the DID (Driver Informtion Display) on an 05 A4 2.0?
    2. Do you know what the RCA voltage output is and how would you hook up amps?
    Thanks
    viziers
  3. #618
    Megalomaniac's Avatar
    Megalomaniac is offline Mr.SQ
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    Quote Originally Posted by jadon087 View Post
    wow thats sick i would love to do something like that, actually exactly like that for my hoe. What year is his?
    I am a newb coming into this and need some advice on where to begin so far all i have put together is
    http://secure.newegg.com/Newversion/...sp?Submit=view
    I wanna do a custom case in the center console as your friend has. but a few more questions i have are what power supply would i need/ other parts?
    95'
    LCD Build
    Console Build
    Quote Originally Posted by viziers View Post
    Hey Mega,
    Thanks
    viziers
    1. There is a way i dont know if you audi fits in this catagory, although it might since its older.
    maybe this?
    http://store.mp3car.com/SWI_CAN_p/com-016.htm
    or this?
    http://store.mp3car.com/SWI_X_Steeri..._p/com-004.htm
    im not sure about the DID you may want to do a search on http://www.mp3car.com/vbulletin/
    2. That all depends on which mobo or soundcard you get. i think, im not certain, you may have to turn the gain up slightly higher than an HU would connect to.
    to hook up to amp you need a 3.5mm to rca cable like this just not necessarily that long
    Quote Originally Posted by Second Skin Rep View Post
    so in closing...
    Don't punch babies..
    ANT
    www.secondskinaudio.com
  4. #619
    spoonraker's Avatar
    spoonraker is offline CarAudio.com Elite
    Sep 2006
    Lincoln, NE
    1,249
    Re: Carputer 101
    90% of the time the preout voltage from a computer soundcard is well below what a typical voltage from a car audio head unit would be. The gains will be set considerably higher for a CarPC, make sure you know what you are doing before you crank it though.
    References : chaunb3400, Team H&K, diminishedpower, pickup1, sublime06, sporty_drew, JRock10, Jando86, sundownz
  5. #620
    jadon087's Avatar
    Jan 2007
    Columbia,Sc
    25
    2,476
    Re: Carputer 101
    Quote Originally Posted by spoonraker View Post
    i plan on adding the alpineH701/c701 to mine to help with the signal voltage/stereo control. Think that will help?
    l
  6. #621
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    god yes!! and more eq options
    so in closing...
    ANT
  7. #622
    Symon_say's Avatar
    Symon_say is offline You can't get me
    Sep 2005
    Dominican Republic
    679
    Re: Carputer 101
    There are some pci cards that have 2 volts of preout and are not expensive.
    Car: 2005 Ford F150 FX5
    HU: JVC KW-AVX830 on its way
    Front Spk: Haven't decided yet...
    Front Spk Amp: Profile AP1040
    Sub: 2 10" Memphis Sclass
    Sub Amp: Audioque AQ1200D
  8. #623
    viziers's Avatar
    Jul 2007
    North Carolina
    91
    Re: Carputer 101
    Quote Originally Posted by Megalomaniac View Post
    95'
    LCD Build
    Console Build
    maybe this?
    or this?
    what if the carputer has a spdif jack on it would that work?
  9. #624
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    Quote Originally Posted by Symon_say View Post
    question should be. does it sound good
    you mean optical? then that would be a digital signal so yeah it would work especially with that h701
    so in closing...
    ANT
  10. #625
    viziers's Avatar
    Jul 2007
    North Carolina
    91
    Re: Carputer 101
    Well the CarPuter i have found and would use would be these. Please tell me your thoughts on the components i have selected. Remember this is also for SQL with amps.
    http://www.cappuccinopc.com/pandora-945-x.asp - CarPuter
    http://www.digitalww.com/store/prodd...sp?prod=EBY701 - TS Monitor
    http://www.cappuccinopc.com/parts/p2140.asp#buy - dc-dc Power supply
    http://www.newegg.com/Product/Produc...82E16834995074 - Security
    viziers
  11. #626
    Ruffy's Avatar
    Ruffy is offline Death to the salad eaters
    Apr 2006
    Las Vegas, NV
    32
    382
    19 Post(s)
    Re: Carputer 101
    There are many ways around that. From USB DACs with higher voltage outputs, to higher end studio level sound cards with swapable op-amps and higher voltages out.
    I currently use a Silverstone EB01 usb dac modified to put out 3V RMS. I plan on replacing it in the future with something else, maybe a EMU 404 usb dac.
    Then theres the alpine h701. use Toslink\spidif out from the carputer and voltage doesnt matter anymore as its optical.
    And yes it sounds great. Computers are used as entire sound production studios, why wouldn't it sound good.
    _______________
    For Sale, PM me
    Comps : Rainbow Audio SLC 265
    Subs : Diamond Audio D6 12" Subs X2
    Amp 1 : Hifonics ZXi 6006 AB Amp
    Amp 2 : Hifonics BXi 1606 D Amp
  12. #627
    spoonraker's Avatar
    Sep 2006
    Lincoln, NE
    1,249
    Re: Carputer 101
    I never said it wouldn't sound good, I just said most sound cards have a lower voltage so the gains will have to be set higher accordingly. Sure you could buy an expensive card, or solder on different op-amps, or buy an external equalizer, but most people don't.
    A really good sound card with high voltage preouts will cost you, and not everybody knows how to replace op-amps or is willing to try it. A processor like the h701 is another way of upping the voltage, but they cost a LOT of money, and the computer is capable of doing all the equalization, time delay, and crossover work, so buying an external unit just to up the voltage is rather redundant and a big waste of money and nice equipment.
    If it's that big of a deal and money is tight, just buy a line driver, although you shouldn't need one.
    Viziers, those components look pretty good. The only thing I worry about is the monitor, it says it's a 7'' touchscreen, but there is a large button panel on the side. So either the screen is much smaller than most 7'' monitors, or the unit its self is about an inch wider than most which could make installation more difficult.
    Oh and I always thought it would be fun to have a fingerprint scanner start the car...you should do it since you have one.
  13. #628
    bland's Avatar
    bland is offline Member
    Aug 2007
    canada
    146
    Re: Carputer 101
    My carputer sound just as good as any cd I'm playing in the head unit. All I"m using for a sound card is this model with the line out.
    I'm in no way setup for sound quality, but it is more than acceptable.
    http://www.creative.com/products/pro...&product=10702
  14. #629
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    Quote Originally Posted by bland View Post
    the LIVE and the X-Fi sound completely different. I know you are using the usb version but had you used the X-Fi soundcard its a world of difference. just a thought for the future for you
    so in closing...
    ANT
  15. #630
    bland's Avatar
    Aug 2007
    canada
    146
    Re: Carputer 101
    A pci card was not a option for me. I'm running the aopen minipc, so usb was my only option. Also i was reading about noise issues on internal cards.
    My first chois was the audigy 2 nx version, but it was unavailable when I built my sytem.
    http://www.creative.com/products/pro...5&product=9103
    This was a hack job, because I rushed to get it in there for my road trip right after getting the vehicle. The sound card is sitting under the pc.
+ Reply to Thread
