+ Reply to Thread
Page 20 of 56 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 ... LastLast
Results 286 to 300 of 827
Reload Thread: Carputer 101
  1. #286
    937DYTBOI's Avatar
    937DYTBOI is offline TL>you
    Mar 2005
    Dayton,Ohio
    28
    6,240
    Re: Carputer 101
    any words on the miny xp
    My Goal
  2. #287
    Ruffy's Avatar
    Ruffy is offline Death to the salad eaters
    Apr 2006
    Las Vegas, NV
    32
    382
    19 Post(s)
    Re: Carputer 101
    Quote Originally Posted by Megalomaniac View Post
    let me rephrase my issue, mine can go into hibernation but wont turn back on, i probally just need to play around with it some more.
    the laptop issues are turning it on, voltage drops, problems with monitors not turning on without use of short cut on keyboard, using the dvd/cd rom (u cant use it without reach for the laptop wherever it may be, unless u have an external, Sound quality...
    u can use a laptop im not goin to stop you, but i dont believe i would use it one.
    Turning it on simple. There's fairly simple kit out there now for this that cost about 15-20 in parts, or 35 premade to facilitate this. It does involve soldering a couple points on the power button of the laptop. Overall not hard. especially if you use a docking station for the laptop. It auto turns on the laptop for you when you start the car, just like a regular carpc startup controller. It also prevents you from restarted the laptop if it was already on and you cranked the car up.
    Voltage drops arent a problem since you use the battery. All You really need is a good protected/regulated power inverter or adapter. I plan on having it go into sleep then hibernation. Charge for awhile and then when the car battery gets to 11.5Volts or so, shut off the charger. It'll still run off battery/hibernation for a good long while. It's basically the same thing people are doing with standard carpcs.
    On most modern laptops if you boot the laptop with a external vga screen plugged in it will auto output to that vga screen. Mine does this no problem. as long as you boot it with the cable plugged in theres no need to use the FN+f5 key
    Also I have a mini handheld keyboard which will be installed somewhere in the car. Doubt I can do the FN+F5 Key combo but so far i have not needed it. My laptops been running in the back seat for about a month now.
    If you make a car pc you more than likely arent going to be using the DVD/CD often. You can just use an external usb one mounted somewhere else in the car if you need it so bad. On top of that there do exsist laptop drive to usb adapters, meaning you can fabricate a slim laptop dvd+rw drive anywhere, same thing you would have to do if you wanted an easily accessable optical drive with a standard carpc. Unless you have a mac mini you're not going to be able to get back to it and load a dvd quickly.
    Sound quality is a moot point since you can still use high quality usb sound cards/dacs. or if your laptop supports it full sized PCI cards(There are many out there, the docking station itself has 3 PCI slots, Dells I believe, A old usable dell with over 1ghz can be had for 250-350, the docking station would be $50) Then theres PCMA Cards.
    I dont like pci sound cards tho due to noise interferance. Especially in a car enviornment. I'd rather go with a decent usb -> optical out -> sound processor.
    Also newer laptops put out alot more power than older ones
    My HP ZE2000 puts out 0.5v From the headphone jack
    My HP DV6105 puts out almost 2v from the headphone jack
    Dont know what my Acer Aspire 5102 puts out as I havent measured it.
    _______________
    For Sale, PM me
    Comps : Rainbow Audio SLC 265
    Subs : Diamond Audio D6 12" Subs X2
    Amp 1 : Hifonics ZXi 6006 AB Amp
    Amp 2 : Hifonics BXi 1606 D Amp
  3. #288
    Megalomaniac's Avatar
    Megalomaniac is offline Mr.SQ
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    u seem to know a lot about the laptop use if anybody asks a question about using a laptop please feel free to answer them.
    im satisfied with my carputer and ur satisfied with urs.
    also some questions people have asked were "can i just use an old IBM laptop off ebay for like $100" so those laptops arent the beefiest of ease of use IMO
    Quote Originally Posted by Second Skin Rep View Post
    so in closing...
    Don't punch babies..
    ANT
    www.secondskinaudio.com
  4. #289
    .::DuD3::.'s Avatar
    .::DuD3::. is offline EE in training
    Oct 2004
    Chesafreak, Va
    25
    4,547
    Re: Carputer 101
    got a quick question. if i were to buy a hu thats dvd compatible, could i aux in to the pc to use that instead of using a separate dvd drive?
    Designated "Fast and the Furious" quoter.
    Pioneer 880prs
    PG Rsd 6.5
    15" Fi SSD w/copper coil
    Alpine PDX-1.600
    Alpine PDX-2.150
    Knukonceptz 1/0
  5. #290
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    no, unless u have a video in on your videocard to capture video...even then there will be a slight delay
    so in closing...
    ANT
  6. #291
    AJČ06's Avatar
    AJČ06 is offline 8====D ---> ( | ) = win
    Jul 2006
    DFW, USA
    10,198
    Re: Carputer 101
    PM me pics...
    Hows it feeling overalll with the carputer?
    http://www.myspace.com/unknownbelow
    Refs: Showrides|IonSQL x2|mattmcss|QtrHorse x2|DaGh0st|bjfish11
    حَتَّى إِذَا اجْتَزْتُ وَادِي ظِلاَلِ الْمَوْتِ، لاَ أَخَافُ سُوءاً لأَنَّكَ تُرَافِقُنِي. عَصَاكَ وَعُكَّازُكَ هُمَا مَعِي يُشَدِّدَانِ عَزِيمَتِي.
    Ebay:aj06silver
    Quote Originally Posted by Reson8 View Post
    Much as I shudder at the thought of potentially seeing your *****, writing caraudio.com on your dick would kick ***. Que the joke about only being able to get up to "CAR" on it....
  7. #292
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    Quote Originally Posted by AJČ06 View Post
    PM me pics...
    I love my carputer...about to invest in an Alpine 701 or 700 processor with controller to get rid of my HU.
    im in the process of redoin my console i dont think youd want to see it.
    old pic before tear down
    so in closing...
    ANT
  8. #293
    AJČ06's Avatar
    Jul 2006
    DFW, USA
    10,198
    Re: Carputer 101
    Doesn't look tooooo rough...
    Ebay:aj06silver
  9. #294
    lamont1's Avatar
    lamont1 is offline Senior VIP Member
    Sep 2006
    Hattiesburg/picayune,MS
    267
    Re: Carputer 101
    man i'm loving this topic
    3 pumped,1 to the front 2 to the back hopping and doing rolling and standing 3's all day
    alpine cda-7977
    orion xtr400.4
    alphasonik pma600
    dd9515d
    ohio gen.200 amp
  10. #295
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    glad to hear
    btw I plan on goin Optical as soon as I find an Alpine h701 or h700 on sale somewhere
    so in closing...
    ANT
  11. #296
    mattf's Avatar
    mattf is offline Veteran of CarAudio.com
    Jul 2005
    28
    4,984
    Re: Carputer 101
    So I am thinking about putting one of these in my car now.
    First question I have is how do the computer parts/lcd screen stand up to the cold? As you know, MN gets pretty cold in the winter. 20-30 below is expected. Would this hurt anything?
  12. #297
    Randy Savage's Avatar
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    Re: Carputer 101
    Quote Originally Posted by mattf View Post
    It's not quite as cold here as it is for you, but it gets quite cold here.
    On really cold days my screen will not be as sensitive on the touch screen for the first ~5 minutes or so. Other then that, I've had no problems with the cold.
  13. #298
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    dont wire the start up control like i did then. i wired mine to were the computer boots when remote started. lets say you dont have a remote start. when you crank to start the car/computer the computer will boot up. But in the cold weather the HDD wont get detected. so i say install a switch to the startup controller,its easy you just hook up a switch to the ignition wire coming to the startupcontroller, like yo do on stereos only diferance is on a stereo you put the switch on the remote wire.
    now with that switch your carputer wont turn on imediately, that gives you time for your car to warm up a bit then hit that switch and bam it will boot fine, or some people have made their own tempreture sensors to heat up the hdd to a certain temp to keep it stable(i dont really know how to do that)
    so in closing...
    ANT
  14. #299
    Dec 2005
    The Colony, TX
    24
    8,146
    Re: Carputer 101
    Quote Originally Posted by snova031 View Post
    so your carputer still runnnin fine any changes?
    so in closing...
    ANT
  15. #300
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    Re: Carputer 101
    Yep, fine and dandy.
    Nothing changed. Waiting till I get a large external HDD to add some games in there (I've got Madden 07, NHL 07, and Battlefron 2142t torrents D/L'ed, but they are 4+gig files), and put in iG 3.0, still using 2.1.
    Might try TinyXP too.
+ Reply to Thread
