Jbl Gti Subs??
Hi im think of buying the jbl gti series subs do u think they r worth it and what amp would u recommend to run it on? or maybe i might install 2 so what amp would you say for that
Model:W10GTie
Voicecoil: 76mm dia
Peak:3000W
RMS:600W
Impedance: 3 or 12 ohms
Sensitivity: 92db
Freq Response: 20Hz-1kHz
Cheers Guys
I would say go for it!! I personally have 2 GTO series JBL 10's and they are very nice.. I also have a buddy with 2 GTi 10's on an Xtant 1001D.. very clean and loud.. They are dual 6 ohm coils, so i would go with a JBL BP1200.1 amp... you could parallel the coils of each sub and then parallel the subs to the amp.. 1.5 ohm load.. will work perfect on the amp and each sub will get 600W rms.
Originally posted by badazzDD I would say go for it!! I personally have 2 GTO series JBL 10's and they are very nice.. I also have a buddy with 2 GTi 10's on an Xtant 1001D.. very clean and loud.. They are dual 6 ohm coils, so i would go with a JBL BP1200.1 amp... you could parallel the coils of each sub and then parallel the subs to the amp.. 1.5 ohm load.. will work perfect on the amp and each sub will get 600W rms.
ok this might make me seem really stupid but i got to know so if i reduce the ohm load to 1.5 ohm then they will be better?
Yes.. the lower the ohms, the more current running throughth amp, so the more power put out. The JBL 1200.1 puts out 1200W rms at 2 or 1 ohm, so at 1.5ohm, each sub will split the power, getting 600W rms each.
acually it puts out more like 1300 at 14.4v
if you get them take pics!!! i've been waiting a long time to see an install with the GTi.
does anyone know any other amps that wud run them gd! because im not to keen on the amps jbl make but i guess they are really gd?
Originally posted by Rad does anyone know any other amps that wud run them gd! because im not to keen on the amps jbl make but i guess they are really gd? If it was me I would spend the extra $$ and get the ampman revolution , I have had both amps and the revoluiton flat blows the JBL 1200 away at any ohm load , seems to use less power , Deifinatly puts out more power by a big margin , I dont care what the ratings are they are close to the same @ 4 ohms and the Revo Rocks ! My pennies !
1990 300ZX Stage IV Twin Turbo
Pioneer Premier P940MP
CDT HD 6.5" Comps
JL 300/4 Active
(2) PG Ti10d
Directed 1100d "WORK HARD.....
PEOPLE ON WELFARE DEPEND ON YOU"
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
