Results 1 to 4 of 4
Reload Thread: Amp turning off/on, repeating, protect? or what...
    Aug 2004
    detroit
    30
    621
    I hooked up one of my new 10" cvxs to a 350.2 (bridged it) and for some reason the amp would come on for a few seconds, bump the sub a little, then turn off for a few seconds... then it would repeat. The sub is wired positive to positive, negative to negative, then ran straight to my amp (bridged)
    the sub has dual 4 ohm coils, any ideas?
    i thought maybe the amp was going into protect, but then i realized that one sub wired to a 1ohm load isnt actually a 1ohm load, but a 2 ohm... right? you need two subs to have a 1 ohm load the way i have my sub wired. so it should have worked because that amp is 2 ohm stable.
    Eclipse, Auidopipe 3000.1?, JL Audio, Diamond Audio, Kicker
    References: PepsiFiend69, jl12w7inabox, pickup1, 88irocz, matt calgary, drubob23, bowens99gt, pesteele, unbonyr, pistons520, characterzero, showrides, RJ_22, Rocky 59, Guy022077, thadman, buckshot, mikeyb, grizzly, lowendtheory, lexani2002, lpmaster, 954runner, flakko, qtrhorse, DaveT, Live4SkimLC, Ridinhi, angrytrucker78, seth350
    Vincent9515's Avatar
    Vincent9515 is offline Senior VIP Member
    Nov 2005
    Houston
    208
    Re: Amp turning off/on, repeating, protect? or what...
    Unhook the subs and see what it does.
    Refs:
    NisAznMonk, Moe Lester, krouchchocolate, InhumanAcura, davidfre21. southwest713, carguy83, nVRuckus, redlinese-r, kisswahili
    AIM: bigv113x
    Boxes:
    www.vincesaudio.com
    ownage9's Avatar
    ownage9 is offline $
    Aug 2004
    detroit
    30
    621
    the amp stayed on when there was no sub hooked up to it...
    Nov 2005
    Houston
    208
    The 350.2 is not stable to 2 ohms mono, as far as I know. So, that's one problem.
    It's stable to 2 ohms in stereo and 4 ohms in mono. You can wire each sub to 2 ohms and hook each one to a separate channel, or wire them in series/parallel to 4 ohms and bridge it (preferred method).
    Refs:
    AIM: bigv113x
    Boxes:
    www.vincesaudio.com
  1. amp in protect mode, dont know why
    By bigdub_diesel in forum Amplifiers
    Last Post: 12-14-2005, 06:37 PM
  2. Amp not turning on
    By Classick96 in forum Amplifiers
    Last Post: 08-28-2005, 04:07 AM
  3. Amp not turning on
    By Decado in forum Amplifiers
    Last Post: 07-27-2005, 03:15 AM
  4. amp protect mode
    By mxryan534 in forum Wiring, Electrical and Installation Help
    Last Post: 03-29-2005, 03:49 AM
  5. my amp keeps going into protect
    By supa93poo in forum Amplifiers
    Last Post: 01-31-2004, 03:34 PM
