Results 1 to 5 of 5
Reload Thread: What the hells is a farad???
    Cieprus's Avatar
    Cieprus is offline Member
    Sep 2002
    Nashua
    33
    68
    Simple question?
    -Rockford Fosgate RFX9300----HU
    -Infinity Kappa 693.51-------------Rear's
    -Infinity Kappa 572.5cf------------Front's
    -Infinity Perfect T-------------------Tweeter's
    -Alpine Type-R SWR-1221D --Sub's
    -JBL BP600.1----------------------Sub Amp
    -JBL P80.4--------------------------Speaker Amp
    -JBL P80.2--------------------------Tweeter Amp
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    A farad is a measure of capacitance
    Cieprus's Avatar
    Sep 2002
    Nashua
    33
    68
    Ya...Sooo? What is a farad???
    20 farads does what? 1 farad does what?
    Is 1 farad = to holding 1000 watts?
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    A capacitor stores electrical energy in the form of a static electric field. We use them to keep the 12 volt power from dipping during peak current draws. The amount of current that can be supplied for a period of time depends on the amount of capacitance and the change in voltage...
    The formula is I = C dv/dt (Amps = Capacitance * Volts per Second)
    In terms that matter to car audio: 1 Farad will supply 100 amps for 100 milliseconds while losing 1 volt. Rule of thumb is 1 farad per 1000 watts works well.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    excelonperu's Avatar
    excelonperu is offline livin it up
    Jul 2002
    Dallas,Tx
    36
    199
    Just got a test about capacitors and everything about circuits on wednesday
    As a matter of physics, the capacitance of a capacitor is measured in farads but you usually use when building circuits units like millifarads, nanofarads, etc.
    Capacitance= charge/volts
    C=Q/V
    you also define a farad as 1 coulomb/volt
    The use of capaciotrs in every circuit are many, almost every circuit found in anything even a regrigerator or a camera has capacitors in it.
    For matters of car audio you will need them to feed your system during small periods of high wattage demands.
    For every 1000 watt you will need 1 farad
    97 cavalier
    Kenwood Excelon KDC - X659
    front: 4x6 infinity refrence plate speakers
    rear: Blaupunkt psx693
    amp for sub: US acoustics 50x2 RMS
    Sub: Kenwood 3005
    Knukonceptz wiring
