Results 1 to 6 of 6
Reload Thread: 2000 Watt H2 12.2 speaker Wire Size - Please Help Quick.
    sheldon186's Avatar
    sheldon186 is offline Junior Member
    Nov 2005
    Detroit
    35
    14
    Icon32 2000 Watt H2 12.2 speaker Wire Size - Please Help Quick.
    I'm about to finish an Enclosure pushing (1) H2 12.2 @ 1 Ohm (2000 Watt RMS)
    The Amp is a D Orion.
    I'm confused why you need large power wires to run amps but use 12 guage wire for the actual speaker.
    Should i try to upgrade the speaker wire size to say 4 or 8 gauge with some adapter?
    bimma85's Avatar
    bimma85 is offline Can't be ****** ;)
    Nov 2004
    midwest
    9,944
    Re: 2000 Watt H2 12.2 speaker Wire Size - Please Help Quick.
    triple threaded....nice
    12awg is plenty
    REFS:JimJ, DBfan187, jimj, ology audio, excelerater, private pastry, kenny pollock, priosonnumber6, johnnyber, mattmmcs, vosschs, lax916, davidfre21, iceteebone, cd6551, vladd and others that I cant remember off the top of my head
    Quote Originally Posted by snb778
    I feel like when im bumpin once it gets dark....the street lights often go out. I was driving home the other night and like 3 street lights went out in like 15 minutes.
    Does this happen a lot to any of you??
    Also if you have had the twix ice cream......isnt it amazing!
    Quote Originally Posted by RumbleNTheTrunk
    damn. 8 10"s?........80" of cone area FTW!
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Also wrong section. There's a wiring/electrical section .
    NG
    http://crunktimes.com/ct/
    nG - BSEE
    KaeZoo's Avatar
    KaeZoo is offline CarAudio.com Elite
    May 2004
    Grand Rapids, MI
    1,107
    You need larger wire for higher currents. Amp power wires have to handle higher currents than speaker wires. If we assume your amplifier is about 80% efficient, it will draw around 200 amps of current from the battery at maximum RMS power. On the other hand, 2000 watts output into a 1-ohm speaker load will produce a current of about 45 amps.
    On paper, 45 amps is a bit high for 12-gauge speaker wire to handle. In practice you'll probably never come close to that kind of continuous power output, but if you want to feel safer, go ahead and upgrade to 10-gauge or 8-gauge speaker wire. 4-gauge would be extreme overkill.
    sheldon186's Avatar
    Nov 2005
    Detroit
    35
    14
    thanks KaeZoo ill prob just go with 10
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Power input to amplifier = DC Voltage = more current.
    Power output from amplifier = AC Voltage = A LOT less current.
    12 guage is more than enough.
    NG
    nG - BSEE
  1. using 12 speaker wire as power/ground
    By jacko in forum Wiring, Electrical and Installation Help
    Last Post: 07-30-2005, 06:16 PM
  2. Wire Size ? Fuse Size ? Battery ?
    By summitboy in forum Wiring, Electrical and Installation Help
    Last Post: 08-11-2004, 09:26 AM
  3. Terminology - Please contribute
    By frozenfire89 in forum General Discussion
    Last Post: 02-12-2004, 10:06 PM
  4. What Size Speaker Wire for Mids/Highs
    By james33440 in forum Subwoofers
    Last Post: 02-15-2003, 03:47 PM
  5. wire size FYI
    By Steven in forum Wiring, Electrical and Installation Help
    Last Post: 10-23-2002, 07:31 AM
