Results 1 to 6 of 6
Reload Thread: Will this set-up work?
    cuseguy's Avatar
    cuseguy is offline Junior Member
    Aug 2005
    Fulton, NY
    30
    This amp:
    http://www.cardomain.com/item/POWLT14402
    with a dual four ohm sub?
    PhatTonyDeMarco's Avatar
    PhatTonyDeMarco is offline C0CK,its whats for dinner
    May 2005
    West Palm Beach, FL
    7,729
    Re: Will this set-up work?
    Nope, dual 4 ohm = final load of 2 or 8 ohms.
    That amp puts out its highest rated power @ 4 ohms bridged, and you can not achieve a 4 ohm mono load with that sub.
    ~Magick_Man~'s Avatar
    ~Magick_Man~ is offline CarAudio.com Veteran
    Apr 2005
    bedford,Tx
    32
    2,149
    well a dual 4 ohm sub would work just fine but you wouldnt be able to get the most out of the amp.
    if the sub was rated at like 300 rms per coil then it would work fine.
    ~Magick_Man~
    XtrmAudioCncpts's Avatar
    XtrmAudioCncpts is offline CarAudio.com Veteran
    Mar 2005
    Fairfax, Va
    31
    4,294
    yeah Tony he didnt say anything about bridging the amp. he could just want to power per coil.
    Cuseguy what sub is it that you are powering?
    Quote Originally Posted by Devillain00
    XAC = pimpin since been pimpin
    cuseguy's Avatar
    Aug 2005
    Fulton, NY
    30
    i was going to bridge it
    cuseguy's Avatar
    Aug 2005
    Fulton, NY
    30
    http://www.cardomain.com/item/POWFUBAR15W
    thats the sub i was going to use
  1. How is your system config set?
    By Slaugh in forum General Discussion
    Last Post: 06-21-2005, 07:16 PM
  2. Best 6.5 inch set for $400 with not alot of midbass
    By ChrominImpala in forum Speakers
    Last Post: 05-21-2005, 06:52 PM
  3. will these work with a hifonics amp?
    By orphe in forum Subwoofers
    Last Post: 03-06-2005, 02:10 PM
  4. Help me set the EQ curve on Alpine 9813
    By Forty-Ouncer in forum General Discussion
    Last Post: 02-01-2004, 10:31 PM
  5. got new subs! will set up work?
    By stangpounder in forum Amplifiers
    Last Post: 10-31-2003, 11:33 AM
