Results 1 to 7 of 7
Reload Thread: whats up with the engine noise
    lowcru's Avatar
    lowcru is offline Member
    Mar 2002
    rochester, ny
    34
    45
    What are the causes of engine noise? I can hear my engine from my interior speakers wich are powered by my head unit and, of course through my subs. Any suggestions?
    IowaBoomer's Avatar
    IowaBoomer is offline Member
    Dec 2001
    Walnut, IA
    97
    Most likely you have a bad ground on your H/U. Instead of using the factory default, run some wire down to a piece of the chassis, but try to keep it as short as possible.
    New and Improved system:
    JL12W7
    Alpine 7893
    JL 500/1
    Big *** Vented Box.
    Eclipse 4'' 2 ways
    All adding up to a new bigger number...can't wait for the new season.
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    disconnect the highs & the sub rcas from the HU. USe a smal test speaker and connect it directly to the HU do you hear noise???
    lowcru's Avatar
    Mar 2002
    rochester, ny
    34
    45
    yes
    dreid's Avatar
    dreid is offline CarAudio.com Elite
    Sep 2002
    Buffalo, NY
    34
    1,924
    9 Post(s)
    do you hear a whining noise as you idle or take off that gets louder with acceleration?? your alt might be shot my friend
    Dave Reid
    SoundWerx
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    doubt it---- best to find where the noise is getting into the HU---------- my advice would be to remove the HU from the dash and connect power------- if noise is still there next would be to pwer it with a isolated supply [ battery or inverter]
    dreid's Avatar
    Sep 2002
    Buffalo, NY
    34
    1,924
    9 Post(s)
    taht could be, don;t rule it out
    i actually just had a tensioner pulley go bad on my focus and I could hear engine noise thru my speakers!!
    Dave Reid
    SoundWerx
