Results 1 to 8 of 8
Reload Thread: ALPINE CDA-7893 vs PIONEER DEH-P9300 vs CLARION DXZ825
    nick310's Avatar
    nick310 is offline Senior VIP Member
    Aug 2002
    Los Angeles, CA
    258
    Ok! Here are the specifications.
    ALPINE CDA-7893
    3-Position HP/LP Crossover (12dB/Oct.)
    4-Channel Digital Time Correction
    Bass Center Frequency Control
    Bass Width Adjustment
    Media Xpander (MX)
    Subwoofer Level Control
    Subwoofer Phase Control
    Treble Center Frequency Control
    3 PreOuts
    3-Color Display with Spectrum Analyzer
    4V Subwoofer PreOut
    60W x 4 V-Drive Amplifier
    Anti-Theft Detachable Front Panel
    Bass Engine Plus
    Detachable Trim Plate
    Dimmer-on Input
    Fader & Balance Controls
    ISO Mount Capability
    Power Antenna Lead
    Remote-on Lead
    Rotary Encoder Volume Control
    S.T.M.(Source Tone Memory)
    Separate Bass & Treble Control
    Silver Swing Face Mechanism
    Versatile Link Ready
    Wireless Remote Control Included
    Chassis Size (W x H x D)in : 7"x2"x6-1/8"
    Chassis Size (W x H x D)mm : 178mm x 50mm x 155mm
    Continous Power Output (Note 2) : 27Wx4
    Maximum Mounting Angle : 30 from Horizontal
    Maximum Power Output (Note 1) : 60Wx4
    Nose Piece Size (W x H x D)in : 6-11/16" x 1-3/16" x 11/16"
    Nose Piece Size (W x H x D)mm : 170mm x 46mm x 18mm
    Operating Temperature (C/F) : 60C (140F) to -10C (14F)
    Power Requirement : 14.4V DC (11 -16 V allowable)
    Pre Output Voltage (Before Clipping) : 4V Subwoofer (2V Front and Rear)
    Weight : 1.5kg (3lbs. 5 oz)
    PIONEER DEH-P9300
    Motorized Slide-Down Face
    Soft Key Button Layout
    Pop-up Rotary Volume Control
    Detachable Face Security
    Automatic Face Lowering
    Detached Face Warning Light
    High-Resolution Organic EL Display
    Over 20 Different Display Modes and Background Patterns
    Automatic and Manual Dimming
    Full-Motion or Still Picture Screensavers
    5-Mode Spectrum Analyzer
    Digital Signal Processing (DSP)
    Listening Position Selector with Digital Time Alignment
    4-Mode Sound Field Control (SFC)
    Variable "Octaver" Bass Control
    Variable Digital BBE Processor
    Supertuner III
    24-Station (18FM / 6AM) Presets
    Station Naming and BSM (Best Station Memory)
    AGC (Automatic Gain Control)
    CD Player with CD Changer Control
    CD Text and Disc Title Memory (48 Discs)
    Scrolling Display for Disc Title Memory & CD Text
    Scan, Pause, Repeat, and Random Play
    Digital Level Reduction
    CD-R and CD-R/W Compatible (when disc is finalized)
    MOSFET 50 4-Channel High Power Amplifier
    Digital EEQ Performance Chip
    13-Band Graphic Equalizer with Auto EQ and Tone Generator
    Easy EQ (EEQ) with 5 Factory and 2 User EQ Presets
    Source Custom EQ Memory (Independent Custom Memory for Each Source)
    Selectable Loudness Control
    IP-Bus System Control
    6 & 12 Disc Multi-CD Players
    XM Digital Radio Ready
    Optional Voice Commander and TV Tuner Control
    Optional AUX Input
    Steering Wheel Mounted Remote
    4-Volt RCA Preamp Outputs (3 pair)
    Sub-Out Low-Pass Filter (5-Position, 18dB/Octave)
    Sub-Out Level Control and Phase Selector
    Independent Front/Rear High-Pass Filter (5-Position, 12dB/Octave)
    Selectable Fader Control
    Automatic Sound Levelizer (ASL)
    Cellular Mute
    Hands-free Cell Input
    Included Wired Microphone for ASL and Auto EQ
    CLARION DXZ825
    Motorized Detachable Face
    Dual 24 Bit DAC's
    Play's CD-R & CD-RW's
    Sirius Satellite Radio Ready
    CeNET
    Controls Optional TV Tuner, Optional Sirius Satellite Radio Receiver, Optional
    DSP/EQ Processor, Optional DVD Changer and 6 Disc CD Changer
    Multi-Changer Control, CD Text, CD Titling, Station Titling
    3 Band Parametric EQ (Beat EQ)
    4 Volt/6 Channel RCA Line Level Output with Non-Fade Volume Control
    2 Channel Aux. Input
    Adjustable Display Contrast
    IR Remote Control
    200-Watt (50W x 4ch)
    Magi-Tune+ Tuner with 18FM/6AM Presets
    Multi-Color Display
    Retractable Rotary Volume Control
    Dual Illumination on Controls
    Full Dot (65x7) Matrix Display
    Screen Saver
    Aluminum Faceplate
    I can get the clarion dxz825 for around $260, the apline cda-7893 for around $280, and the pioneer deh-p9300 for around $350. Please help me decide which head unit to buy.
    Jul 2002
    Cali
    122
    It really depends on the features that you want. They all seem to have nice features to them. I can say that I have the Pioneer DEH-P9300 and Im quite happy with it. Just try to figure which features are the most important to ya. Good luck with your choice!
    NP
    Head unit: Pioneer DEH-P9300
    Mids and highs: Pioneer 3 ways and seperate pioneer tweets
    Mid/Highs amp: 1 MRV-T320 Alpine
    Subs: 2 Audiobahn AW1000X's in a ported box 4 cubes tuned to 30 Hz.
    Sub amps: 2 US Acoustics USX800D one for each sub
    Cap: Lightning audio LSD10 1 Farad cap with digital display
    Alternator: Propower 175 amp hot rated alternator
    ***Warning***
    Got rid of my US Acoustics USX-2080 mid/high amp because it made noise =/ The Zeb also dosn't stand behind what it sells
    nick310's Avatar
    Aug 2002
    Los Angeles, CA
    258
    well i want a head unit with a nice equalizer built in, how's the eq on the p9300? i know that the clarion and pioneer head unit has one built in, but the alpine doesn't.
    mavihs's Avatar
    mavihs is offline Junior Member
    Jul 2002
    UK
    35
    26
    I would go with pioneer or alpine, i dont think clarion quality is up to par with pio's or alp's.
    greed's Avatar
    greed is offline Member
    Apr 2002
    ny
    33
    dont forget bout that mediaxpander on the alpine that is great
    nick310's Avatar
    Aug 2002
    Los Angeles, CA
    258
    i didn't notice the alpine featured the mediaxpander. can you explain more on what it does.
    Jul 2002
    Cali
    122
    It's got a nice eq it even comes with a microphone so that it can sense your vechicle's acoustics and auto set it up for you but it's just 1 way you can do it.
    NP
    ***Warning***
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    36
    8,044
    out of all those i would say go with the 9300 i have it for another 7hours or so in my car b/c i'm taking it out to put my 940 premier in. the only reason i upgraded mine is b/c i wanted the 6volt output instead of 4 and the old p1r crossover network so i can run 300watts rms to my componets without frying em hehe. anyway i'd go with pioneer personally i hate anything alpine and clarion is alright.
    adam
    2006 Bright Island Blue 6s: stock 6 disc in dash, Hertz Hi-Energy 6.5" comps, MB Quart Ref 12", eclipse 5-channel sub amp.
    Car mods: Lowered on Mazdaspeed springs with Koni Yellow shocks, Racing beat front/rear sway bars with AWR end links, LED turn signals, tail lights, front side markers, 18" ADR Cypher rims, 55w HID's in low beam and fogs, 5% tint all the way around. No go fast mods yet...tuning and Mazda6 don't go well together .
    Steve a.k.a. ss3079: So this one lady goes, "These ignorant people who drive around blasting there music, they cant hear emergency vehicles"
    So that set me off, and I said "Well then why do they let deaf people drive?"
    AOL: JmKeenen
