Results 1 to 4 of 4
Reload Thread: SLA - Source Level Adjuster what does it do?
    95Prober's Avatar
    95Prober is offline CarAudio.com Elite
    Nov 2004
    Canada
    1,181
    23 Post(s)
    hi. well after i hook my mp3 player to my pioneer head unit via the proper cables and though the pioneer aux. adapter. i want to make sure i get the correct volume. i heard of players that play very quiet. i also read that this "SLA" solves or helps the problem. im just curious what it actually does and how should i set it? anyone using this feature with an mp3 player hooked up, who could help out would be great!! or anyone for that matter
    thanks
    MY SET-UP :
    Head Unit :Pioneer Premier P660 w/ card remote
    Subwoofers :4-12" Pioneer Premier TSW-1241 (Dual-Voice Coils)
    Sub Amps :2 Zenon ASB-2200.1
    Speaker Amp:Soundstream Rubicon 604 (4Ch.)
    Rear Speak Fill:6x9 Infinity's
    Front Speak:CDT (CL-641 3-Way Comps in custom kickpods)
    Wires/Cables/Installation :2 runs of 0/1 guage, Knukonceptz RCA's, battery terminals, fuseholders, and 12,14 guage speaker wire and.. The Big 3
    Sound deadening : 30sq.ft of Secondskin & 150 B-Quiet Extreme for doors etc., 200 sq.ft of Edead v.2 for floors and trunk
    Box:6 Cu.Ft @32Hz
    Refs:scottyk,Fuknmovin,Bavarian3,Blados,Blazrgreg, juckstapose,
    acousticguitar,IonSQL,SQBubble,dragnix,02parkave,
    DUMPED
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: SLA - Source Level Adjuster what does it do?
    Sounds like a fancy name for a LOC (line output converter)...but I haven't heard of that specific term before.
    95Prober's Avatar
    Nov 2004
    Canada
    1,181
    23 Post(s)
    Quote Originally Posted by Jack Frost
    well, under the pioneer specs it lists that. "SLA"
    MY SET-UP :
    Box:6 Cu.Ft @32Hz
    DUMPED
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Source level adjustments allows you to adjust the level of each source in relation to the AM/FM tuner.
    You can, for example, increase the level of the CD player so that at volume 30 (for example) it will be louder than the tuner at volume 30. Same for the auxillary inputs.
  1. Installed a New HU why are volts reading 12v on guage?
    By APitBullT in forum Wiring, Electrical and Installation Help
    Last Post: 06-11-2005, 10:05 AM
  2. Humming Noise Responds to RPM's
    By ugmoe2000 in forum Amplifiers
    Last Post: 06-08-2005, 05:48 AM
  3. Common Sound Deadening Terms Made Easy
    By sammy1 in forum General Discussion
    Last Post: 12-04-2004, 02:03 AM
  4. Same DB Level = Same Amount of Bass?
    By FullThrottle7 in forum Subwoofers
    Last Post: 08-13-2004, 05:10 AM
  5. HU's Line Level Output to AMP's Speaker Level Input
    By Unregistered in forum General Discussion
    Last Post: 02-09-2002, 03:51 AM
