Results 1 to 10 of 10
Reload Thread: Which Amp is good for VEGA 10''?
    <IowaBoomer>'s Avatar
    <IowaBoomer> Guest
    I have a Vega 10'' sub, and if I didn't blow it, I blew the amp. I believe it has a 400 watt max capactiy, so I need a farily inexpensive amp that would deliver a pretty good sound with it and not blow it. If I did blow the sub, what is a good new setup to use with a Lanzar 1600 cd player (60X4)? I have a weak *** PUNCH 250 amp, so if that could be used, and apparently I won a THUMP 10'' sub on ebay for $1. I doubt its worth a ****, but for a buck.....
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    45
    1,057
    iS It an SS or a vega series? Vega series is 300 RMS and should work with the Fosgate 250..unless its a DVC Not sure about the SS line.
    Mike
    Your friendly neighborhood subaru freak!
    <IowaBoomer> Guest
    I couldn't tell you what kind (I recieved this from a friend), but it is black with a red trim on the outside and VEGA in red in the middle.
    mp2697's Avatar
    mp2697 is offline Junior Member
    Dec 2001
    chicago
    iowa boomer<br />lets say ur vega sub is 300watts. if u hooked up ur amp mono u prob blew the speaker, even though ur amp has small power rockford still under rates there amps.
    mp2697's Avatar
    Dec 2001
    chicago
    and one other thing i hope they are paying u 2 take that thump speaker!
    mykeys's Avatar
    Nov 2001
    South Prairie, Wa.
    45
    1,057
    Only the vega series has the red surround. Now on to the testing to see if the sub is blown.. If you have a multi-meter check the resistance..if it isnt withing.5 of either 4 or 8 then it's done. If you dont have one take a scrap piece of speaker wire and attatch it to the sub then take the other end and touch them to a small battery (I use AA) if the speaker moves then the sub isnt blown..If it's a dual voice coil you will need to check both coils. One other thing The sub has a max input of 600 watts so no the amp shouldn't have killed the vega..It's possible but unlikely. Fosgate doesn't underate their equipment that much I am afraid to say.
    <br />Mike
    <Ryan>'s Avatar
    <Ryan> Guest
    Rockford doesnt overrate their ****? That is a ******* comment. I had a 500a2 raterd at 742 watts, 242 watts over its said power! Don't tell me that isnt underrating.
    <IowaBoomer> Guest
    Well, the sub isnt blown...just a loose wire or something. I'm only paying $16 for the sub, including shipping, so its worth a shot on the thump amp, at least for a lil more power boost. Ok, now as a newb, I would like a dictionary of some sort. What does mono, crossover, OHM, ect mean? I really wanna know all about my sub, not just like it to go boom.
  9. #9
    mykeys's Avatar
    Nov 2001
    South Prairie, Wa.
    45
    1,057
    Mono is the sum of both left and right signals.. (no stereo sound)<br />Crossover active and passive<br /> Active is a powered device that seperates frequencies one or more times to get to the correct amp speaker combination. they are put in b4 the amp . say you have a 4 channel amp with two tweeters and two midrange speakers.. the crossover sends all frquencies from about 3000 hz to the tweeter and all frequencies from about 80hz- 3000hz to the midrange.<br /> Passive can be a series of inductance coils and papacitors to seperate frequencies after the amp to the mid and tweeter.<br /> Ohms are the measurement of resistance..Everything has resistance, speakers all have dfferent resistance so is important when figuring out what you are gonna do with a system..<br /> If an amp was only 4 ohm stable you wouldnt want to run 2 sets of 4ohm components to it becuase the speakers would have a resistance of 2 ohms.. The amp would probably work for a while but after a time the extra power the amp is trying to put out would kill it.
    Ryan, I did not say they don't do it I said they don't averrate their amps by that much..I am not here to start trouble only to provide what info may help...(My opinion)-> Rockfrod makes a good product they just dont sell anything I would use..their amps just dont sound right to me. I would recommend them to anyone who is into stereos I just will never have another one.
    Mike
  10. #10
    Nughuffer85's Avatar
    Nughuffer85 is offline Junior Member
    Dec 2001
    Athens, Alabama
    just go online at <a href="http://www.rexstores.com" target="_blank">www.rexstores.com</a> and order a 450watt jensen amp i think for $130
    crack pipe
  1. which amp is best for my situation (need help fast)
    By *TheVirus* in forum Amplifiers
    Last Post: 12-29-2007, 03:55 PM
  2. Which amp is good for my speakers?
    By TeeZee1000 in forum Amplifiers
    Last Post: 06-21-2004, 01:24 AM
  3. Which amp is good enough?
    By nyclancer in forum Amplifiers
    Last Post: 05-06-2003, 05:58 PM
  4. Replies: 4
    Last Post: 04-05-2003, 05:45 AM
  5. which amp or amps for a tumult????
    By abcdefg in forum Subwoofers
    Last Post: 11-25-2002, 09:30 PM
