Results 1 to 15 of 15
Reload Thread: yellow top batteries
    Sspider's Avatar
    Sspider is offline CarAudio.com Elite
    Feb 2002
    new york
    648
    can the optima yellow top battery be used as the cars only battery?
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    i recomend the red top...i believe that its designed for that...
    Sspider's Avatar
    Feb 2002
    new york
    648
    will the yellow work tho?
    or will ti get messed up or not work?
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    if im not mistaken it would...i would recomend going to the optima website...good luck
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    don't use a yellow----they are for SLOW discharge & recharge
    Sspider's Avatar
    Feb 2002
    new york
    648
    so the red top is for the main battery?
    i have seen pics with the yellow top in the main battery areas? wuts up with that?
    bootleg's Avatar
    bootleg is offline Got Adire?
    Mar 2002
    San Antonio, TX
    443
    You'll see that because most people use them for their high amp numbers.
    '94 Dodge Ram Std. Cab Sport Red
    100' Sound Deading
    1/0 Power & Ground
    Adire Audio 12" Shiva
    Custom Sealed Fiber-glass Box
    '03 Spring Install:
    Clarion DXZ635MP
    US Acoustics USX2100
    US Acoustics USX2080
    ID & Adire Front Stage
    Adire Audio 12" Shiva Mk. III
    Sspider's Avatar
    Feb 2002
    new york
    648
    well yea, dats what i wanted to find out, as of right now i'm running 2 amps..
    for about 1500 watts...
    but i will be expanding to about 1800-2000 watts in a few months...
    but i was confused as to which battery could be used for what, i read that the red top is for starting, and the yellow is for an xtra battery, but can the yellow be used as main battery instead of an xtra, i just want to have the best so that i dont get stuck out in the middle of no where, again...
    my alt died before and my battery quickly drained, now i habe a 105 amp alt...better then the 8o i had before....
    sspider
  9. #9
    i3abyjay25's Avatar
    i3abyjay25 is offline Get F'n Loud
    Aug 2002
    Dallas, Georgia
    38
    2,128
    1 Post(s)
    yeah i have the yellow top and a 1 fared cap, and its allright.. but te red top is made for the whole car
    Fs/t
    Orion 2500d
    Orion 4004
    250 amp alt w. external voltage reg. for a ford explorer
    Refs: Electrodynsmic, Millerboy, Ugaboiii, Ezekiel81923, Toaster, Team Psi, KickerCivic1, MatrxxDude, TommyK90, Xterra02_Pat
  10. #10
    geonn's Avatar
    geonn is offline oalright
    Jan 2002
    minden, MI
    32
    the red top is a starting battery pretty much and isnt really made for big systems but the yellow top is a deep cycle and lasts longer with a system it is made to start the vehicle and run your system better with less strain if i remember right
  11. #11
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    deep cycle = slow charge & discharge--------meaning you shouldn't even use one in your car.
  12. #12
    more_spl's Avatar
    more_spl is offline only have 1, but it's 12"
    May 2002
    Winnipeg
    32
    1,108
    so why do people use them? when u say slow discharge, does that mean they drain slower? becuz i only see yellow tops.. are they just for use as a "system battery" ?
    i decided not to have a signature
  13. #13
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    people use them cause everyone tells them to use them---- they are designed for taking the steady electricial load slowly discharging from something like a trolling motor and then be slowly recovered with a charger. They can also be used in an design where the alt is OVERLOADED and the battery needs to help with the load ALL THE TIME then be recovered at the end of the day------with reduced load on the alt so it can charge it OR a charger --------high cycling. THEY are not made for high current draws like a starting battery or a system ---though the site says to use them for systems. Read the FAQ on the site. They are not for high current rather they are for HIGH CYCLING---hence DEEP CYCLE
  14. #14
    bootleg's Avatar
    Mar 2002
    San Antonio, TX
    443
    Well traditionaly they are for slow charges and discharges but the new gel celluar desing that they incorperate allows them to be used for normal car batteries. They have great success in most as a peice in a multiple battery setup.
    100' Sound Deading
    1/0 Power & Ground
    '03 Spring Install:
    Clarion DXZ635MP
  15. #15
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    no where in their web site or any other website did I see that a deep cycle battery can be use in a high current manner
