Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: How to wire up 11 LEDs off 12v source?
    Spud2388's Avatar
    Spud2388 is offline "The Spud-n-ator"
    Apr 2005
    Iron Station, NC
    632
    Ok, I made a custom Alpine logo out of 1/4 inch plexi glass and I plan on puting it on the front of my box. I'm going to paint the front of each letter (11 letters including the 5 slash marks) silver and frost the sides of the letters. I'm then going to put one blue LED behind each letter to allow the edges to glow blue and let the front stay silver. (My hopes is that diring the day, the silver letters will be seen and diring the night, the blue outline of the letters). I'm going to be running it off of a 12v source, and need 11 LEDs wired up. How will i go about this? I will probably use 3mm LEDs, if that makes a difference, and they will be blue.
    Any suggestion will be greatly appreciated.
    Black_Jesus's Avatar
    Black_Jesus is offline The Unexpected
    Aug 2004
    lamest place humanly possible
    1,743
    Re: How to wire up 11 LEDs off 12v source?
    parrallel or however its spelled
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    wouldnt running them parallel send 12v to each LED???
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    Nevermind people, i decided to go with 16 LEDs to make sure the edges glow well. I plan on doing 4 sets, wired parallel, with 4 LEDs in each set, wired in series. LEDs are 3v. Thanks anyway though!
    How bright are 16 blue LEDS?
    Oh, and pictures will be up once i get finished!
    Aug 2004
    1,743
    yes, parallel would send 12v to each LED
    dont make it hard on yourself.. use 12V LED's...
    slicks5150's Avatar
    slicks5150 is offline got a$$ ? ? ?
    Mar 2005
    ohio
    470
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    Is it ok to cut the LED legs (pos and neg wires)? I'm kinda limited on space and need all the room I can get.
    myvanpounds's Avatar
    myvanpounds is offline I dont own a van any more
    Oct 2002
    Cincinnati, OH
    33
    759
    Quote Originally Posted by Spud2388
    yes, I always cut of any excess after the soldered connection
    2005 F150 XLT Supercab. 5.4L 3.73
    HU: Kenwood DDX-7015
    Sub amps: 2x autotek xs900.2's
    Midbass amp: autotek xs550.2
    Front stage amp: audison LRx 2.250 - FOR SALE
    Midbass: 2x eD 7Kv.2 (RIP lonny)
    Components:Phoenix Gold Rsd 6.5's - FOR SALE
    Electrical: Optima, Knukonceptz, Streetwires
    Subs: 4x eD 9Kv.2's
  9. #9
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    33
    15,426
    21
    id wire up 4 sets of 4.
    wire each set of 4 LED's in series, and wire them all to the same power and same ground. that way, each LED will get 2~3v (they usually want about 2.8~3.2v depending on color and brightness) and they should work fine. make sure you use a REALLY fine jigsaw blade (or better yet, a hacksaw\detail saw) to cut your letters. scribe your line with a ruler, and GO SLOW.
    any uneven edges in the plexi will DEFINATLY be seen quite eaisly. i would cut them all out, paint them with some nice highgloss krylon plastic stuff (paint the back too, you will know why later), then maybe a coat of clear and some wetsanding, then use some 80 grit on the edges to get any paint off there, and frost them up nice. i would then sand your LED down so its flat on the top (make SURE you dont sand down to the actual diode inside the plexiglass LED casing) and drill a hole in the backside of your plexiglass shape (preferably in the center) and hotglue the LED in place.
    the painted surface will act like mirrors on the inside, reflecting all the light toward the frosted edges and not escaping through the clear reverse side of the letters
    tip when painting plexiglass - if its clear, and you want a mirror finish, paint the INSIDE of the plexiglass, and you wont have to sand a single thing
    NEVER EVER use alcohol to clean plexiglass eaither. its a big nono.
  10. #10
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    Thanks man, that solved a lot of my problems right there. I didnt think about painting the back side too to allow the light to reflect to the ends. I have already cut out the letters (used a dremel tool and files and sandpaper). I'm getting ready to go to radioshack to get some LEDs and I will probably drill a hole in each letter (not all the way through) and place the LEDs in there. I'm going to have to make a panel to glue all of my letters to and to give me something to run my wires on, since it's going on the front of my box (which will allow me to drill one hole in my box and pass the wires through the front and out the back). Thanks again!
  11. #11
    lsurulzes's Avatar
    lsurulzes is offline Junior Member
    Dec 2004
    Baton Rouge, LA
    Dont buy them from Radioshack.
    You will be disappointed at how dim they are and how much they cost.
    The website I get mine from when i mod Xboxs and computers is 123leds.com.
    They are cheap and have good brightness.
  12. #12
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    Thanks for tellin me that 2 days after i bought them! i was dissapointed when i got them, they were only $1.12 each, but they are pretty dim. How much more brighter are the LEDs from 123leds.com than from radioshack? i mean, if i get more from radioshack, i'm going to have to get at least 21 more to add to the 12 i have now, just to let the sides of the letters glow well (right now, there kinda dull).
    Also, i have the LEDs shining directly into the back of the letters. Would scuffing up the top make it brighter and give it more dispersion to help reflect the light to the sides?
  13. #13
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    Well, i ended up ordering 50 blue LEDs from oznium.com. The comments that were placed were pretty good, so i'm going to give them a shot. My question is, is what is a safe voltage to run these puppies at? Heres the specs for all the colors http://www.oznium.com/led . Remember i got the blue ones. I'll post pics when i get done with my little project, i promise!
    Thanks, SPUD
  14. #14
    Oct 2002
    Cincinnati, OH
    33
    759
    www.superbrightleds.com also is a great place to order LED's i've ordered many times from them and only had one problem, which when I called them I found out that the order never went through
    Subs: 4x eD 9Kv.2's
  15. #15
    Spud2388's Avatar
    Apr 2005
    Iron Station, NC
    632
    I looked at superbirghtleds.com, but decided to go with oznium.com instead. I just need one question answered, at what volts should i run these LEDs at. Heres the specs, http://www.oznium.com/led , I got the blue ones.
  1. What size speaker wire to sub?
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-18-2006, 09:04 AM
  2. IN NEED OF URGENT HELP>> ground wire to jl amp question
    By pimpn04coupe in forum Wiring, Electrical and Installation Help
    Last Post: 06-25-2004, 10:49 AM
  3. WalMart 4 Guage Wire
    By i3abyjay25 in forum Wiring, Electrical and Installation Help
    Last Post: 11-01-2003, 04:16 PM
  4. help NO POWER PLEASE! URGENT
    By Alpine4life in forum General Discussion
    Last Post: 10-08-2003, 03:17 PM
