Results 1 to 5 of 5
Reload Thread: A Couple Of Questions
    Ted5986's Avatar
    Ted5986 is offline Junior Member
    Oct 2004
    Rockaway, NJ
    19
    first off i have a 95 mercury sable. I also have 2 15" Orion Hcca subs. I want to get into small competitions or big ones if i can. i know a good amount about subs, amps, fiberglass, etc. now my questions. i need to know what frequency i should tune my box to. Next, If box is at 35 hz than what should amp be tuned to? last, is this a good amp to go with:
    Peak Power : 3000 Watts
    RMS Power at 4 ohm: 350W x 2
    RMS Power at 2 ohm: 700W x 2
    RMS Power at 1 ohm: 1000W x 2
    1/2 ohm Stable stereo power: 1500W x 2
    Frequency respons: 9Hz to 50kHz
    Signal-to-Noise Ratio: >105 dB
    Channel Separation: >90 dB
    Low Pass Crossover: 50Hz - 100Hz
    High Pass Crossover: 120Hz - 720Hz
    Bass Boost: 0-+18dB
    Bass Boost Frequency: 50Hz - 100HzHigh Current Operation
    Remote Level Control
    VU Meters (Power Level)
    Cooling Fans
    Line Output for System Building
    Gain Control
    Power and Protection LEDs
    MOSFET Power Supply
    Input Voltage Switch: 100mV-2V/2V-8V
    Dimensions: 20.125" x 13.375" x 2.75"
    2-year Manufacturer's Warranty
    thank you for your time.
    TrlcKed_OuT's Avatar
    TrlcKed_OuT is offline CarAudio.com Elite
    Feb 2005
    las Vegas
    1,033
    10 Post(s)
    Re: A Couple Of Questions
    sounds like a audiocrap amp.....
    Current system:
    03 Ford Explorer
    iraggi 300amp alt (on its way)
    Red top under hood and deka 9a31 in back ( on its way)
    stock mids and highs
    Pioneer Z110bt headunit
    1 18'' TC9/Audioque In 6cubes tuned to 32hz
    Audioque 3500D
    Handles the lows just fine
    SSS 18734's Avatar
    SSS 18734 is offline Dollar Menu Millionaire
    Mar 2005
    Kansas City, MO
    5,457
    3 Post(s)
    man if you plan on competing you need to tune anywhere from 40-50hz. 35 is is more for SQL
    And just wondering... how do you tune an amp?
    Bought From:
    Absolutnockout, zachzchw, Untouchable11, j3bus2k3 (x2), 92c1v1c, jeeper07, acubsfan, bkjt05, Goldenknob, Goindef154, Basscourt2009, TeamSouthrnBass, oldschoolboomer, 99grandprixGT
    Sold to:
    Gearguy2001 (American Bass SQ780)
    Tw1st3d13 (2 Fi BL 15's)
    LightningStryk7's Avatar
    LightningStryk7 is offline Senior VIP Member
    Mar 2005
    Colorado
    279
    I think he meens gain setting / xovers?
    Car: 1999 Plymouth Neon
    Head Unit: Alpine CDA-9853
    Components: RE RE comps in some custom kick panels.
    Subs: 1x Alpine Type R 1242D In a vented 33 hz 3cuft box. (redesiging)
    Sub Amp: 1x Alpine MRD-M301 mono amp (400 rms/14.4volts @ 2ohms)
    Speaker Amp: Infinity 7520a (97 rms x2 /14.4volts @ 4 ohms)
    Ted5986's Avatar
    Oct 2004
    Rockaway, NJ
    19
    yes i was referring to gain and crossovers. thanks smart a**
  1. couple amp questions
    By LightningStryk7 in forum Amplifiers
    Last Post: 04-25-2005, 01:42 AM
  2. A couple questions regarding sounds...
    By nikosbuddy in forum Subwoofers
    Last Post: 03-24-2005, 09:10 PM
  3. Couple questions from newby.
    By Dtowncats in forum Wiring, Electrical and Installation Help
    Last Post: 12-28-2004, 11:14 AM
  4. Couple of short ported questions
    By marcopolo in forum Enclosure Design & Construction Help
    Last Post: 12-08-2002, 10:26 AM
  5. Hey, Couple Questions
    By jonnyboy in forum Wiring, Electrical and Installation Help
    Last Post: 07-31-2002, 01:34 AM
