Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: attaching boxes together?
    mustangowner's Avatar
    mustangowner is offline still wangin'
    Mar 2005
    Shelby,AL
    34
    609
    1 Post(s)
    I am going to attempt to build 2 seperated ported boxes for my 2 alpines. What I would like to do is somehow attached both boxes together so i can take both subs out seperately so its not so heavy. the thing is i can't think of a way to do it...
    Maybe use some type of latch or something. Has anyone did anything similar to this before? please give me some ideas, any suggestions welcome.
    2000 Mustang GT Coupe (yeah, it's mean)
    Headunit -Pioneer deh-p6700mp
    Amp - Power Acoustic A1800db @ 2 ohms
    Subs -RE Audio 10" SE
    Box -at home in a ported box @ 1.5 cubic ft. net tuned to 33 hz
    Components -factory mach 460
    Electrical System -Stock with "BIG 3" (2 gauge wire)
    Wiring -4 Gauge Power & Ground
    REFS: Ridnclean, schrummy, hrtbrk1, mr_kebo, Ridinhi, kharps, mk_, corto
    Quote Originally Posted by Blunt
    why is it that all these idiots wanna be heard from blocks away? Do you buy your system for everyone else or for yourself?
    jrz126's Avatar
    jrz126 is offline Senior VIP Member
    Aug 2004
    Erie, pa
    477
    Re: attaching boxes together?
    I read in another thread about someone using hindges to secure the box to the trunk to keep it from sliding. They would just pull the pin inside the hindge (seperating the hindge into 2 pieces) when they wanted to remove it.
    my latest completed project. My new work in progress, (62 leds in the roof) check out my cardomain site at http://www.cardomain.com/id/jrz126 (page 2)
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    36
    368
    Metal rods and cotter pins? Make a "clamp" with some threaded rods attached to an mdf panel? Make the entire thing removable, so you canlosen it up, take the "clamp" off and then the other box.
    ruckus's Avatar
    ruckus is offline Banned
    May 2005
    Miami, FL
    44
    1,879
    What I would do which is a pretty cleaner looking is add an extra piece of mdf on the side of each box and shape them like a giant dovetail so one box slides into the other box. You can carpet the outer pieces of the dovetail and when put together it looks like one piece but to seperate just pull the 2nd box out. If i had my photoshop here at work i would illustrate.
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Quote Originally Posted by ruckus
    Good Idea, not Mspainted to scale
    Attached Thumbnails Attached Thumbnails attaching boxes together?-dovetail.jpg
    Mar 2005
    Shelby,AL
    34
    609
    1 Post(s)
    that just gave me an idea...what i could do is take a small block, maybe 8 x 8 x 3/4 mdf and cut out an R in the block. Then screw the block to the box (with the r out of it) and paint the R that was cut out red (black boxes) and slide the R into the block that the R was cut out and the boxes are locked together...how would i get the R out though????
    ruckus's Avatar
    May 2005
    Miami, FL
    44
    1,879
    LOL too elaberate a design and not well thought out. I'll stick with my way. easy to put in and remove and clean looking
    Mar 2005
    Shelby,AL
    34
    609
    1 Post(s)
    like this...
  9. #9
    TPABlazer's Avatar
    Oct 2003
    Fort Myers, FL
    36
    368
    Wait? whats holding the boxes together? the R? the block? the r block? I'm lost
  10. #10
    ruckus's Avatar
    May 2005
    Miami, FL
    44
    1,879
    I get it the Red R is suppose to be a solid piece and the cutout outline of the R is split half on each box. The Red R pops in like a lego and holds the 2 pieces together. 2 flaws though.
    1) 3/4" is not enough to hold that R in, the vibration of the bass will pop it out.
    2) you would need some type of lip or handle to remove it if it was flush with the outer boards.
  11. #11
    Mar 2005
    Shelby,AL
    34
    609
    1 Post(s)
    velcro on the back of the R will hold it in place...wont let it rattle out. I will have to think about a way to remove it...maybe a small eye screw or something similar that is very small and not very noticable?
  12. #12
    THUNDERBIRD's Avatar
    THUNDERBIRD is offline CarAudio.com Veteran
    Feb 2005
    LANSING, MI
    2,316
    make a3/4" mdf panel that will cover the front so u dont see the seam and also use it to flush mount the subs and screw it in
    94' thunderbird *parked*<
    4.6 V8 with a shift kit
    clarion dxz 645mp clarion sirius tuner
    ED 6000v.2- front jbl 5.25 comps- rear
    dynamated and edeaded trunk lid, rear deck, front doors
    Big 3 in green of course
    viper 791xv w/ battery backup
    3 jl 10w0
    2000 ford ranger supercab 3.0v6 4x4
    stock hu
    alpine mrp-m350
    2 9kv.3's
    clifford matrix rsx 50.5x
    spring time getting clarion MAX675VDII and front components possibly jbl's again
  13. #13
    pwnt by pat's Avatar
    pwnt by pat is offline Pat for Prez 2024 - vote!
    Sep 2004
    Pa
    30
    2,172
    1 Post(s)
    You should just do this: make the two boxes but use two common, opposite face sides, so the front and back. You can have a common center chamber too if you wanted to save on wood. That way you have two identical, independant chambers that look like one combined chamber from the front and has added stability 'cause more than one face are common.
    carputer - h701 - c701 - dynaudio mw170s - si mag 15 - ss rubicon 604 x2 - ss rubicon 1002
    coming soon:
    seas w15cy - alpine spx177r tweeters
  14. #14
    Mar 2005
    Shelby,AL
    34
    609
    1 Post(s)
    sounds like a good idea but i have spent hours designing the box i have. It took so long to design it i started to give up on it. But i played with my dimensions and got a desent looking design. the port is unlike any other i have seen...not sure if it will sound right but i will give it a shot.
  15. #15
    Sep 2004
    Pa
    30
    2,172
    1 Post(s)
    not common center chamber, but board. my bad
    coming soon:
  1. Output in different boxes
    By Jtsky in forum Subwoofers
    Last Post: 05-18-2005, 08:25 PM
  2. Boxes boxes boxes....
    By Big-Cat in forum Subwoofers
    Last Post: 07-14-2002, 02:20 AM
  3. Louder Boxes?
    By Daniel in forum Subwoofers
    Last Post: 06-18-2002, 02:32 PM
