Results 1 to 5 of 5
Reload Thread: Round Port tuning Help needed
    hookdupexpo's Avatar
    hookdupexpo is offline Member
    Feb 2004
    Lewes, DE
    148
    Alright, im building my first box, and got all the measurements and think it should go pretty easy since my dad is good at all that handyman stuff. I know how to use the calculator to get the tuning thing, but i wanted to use two round ports to minimize port noise. So if it says for example 30 in long for a 4 in. pvc, then how long would it be if i wanted to use 2 4" PVC's? Also, is it worth it to spend like $12 each on those flared ports, or will it work alright if i just sand the edges on some pvc? Thanks for any help.
    Feb 2004
    Lewes, DE
    148
    Re: Round Port tuning Help needed
    any help?
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    Adding another port means you have to double the length basically, so you would need two 60 inch ports and that is why many use the slot ports. Depending on the sub you can easily get away with a single 4 inch port that is flared by a router or sandpaper or buy the flared one.
    Nov 2004
    TriState Area
    32
    3,888
    23
    search for georges box making. calculate from slotted area to cylindrical area. Bam.
    myspace
    1993 Volvo 960 Luxury Sedan
    Refs: Sake Pho Sho, Silentheaven389, macmood, iamslain, lemans23, desertheat (3), monte_carlo97 (7).
    Feb 2004
    Lewes, DE
    148
    thanks, i got it...
  1. need help with port tuning..
    By cheeseburger35 in forum Enclosure Design & Construction Help
    Last Post: 05-10-2005, 11:50 AM
  2. Port Tuning Formula Help
    By Decipha in forum General Discussion
    Last Post: 05-08-2005, 11:10 PM
  3. What's Wrong Below Port Tuning?
    By BOOKER in forum General Discussion
    Last Post: 01-21-2005, 07:10 PM
  4. Round ports w/ port noise or slotted vent?
    By pacho in forum Enclosure Design & Construction Help
    Last Post: 01-06-2005, 07:37 PM
  5. building a ported box with a round port question...
    By g30ffr3y in forum Enclosure Design & Construction Help
    Last Post: 12-20-2004, 08:59 PM
