Results 1 to 12 of 12
Reload Thread: Will tuning change with this?
    pacho's Avatar
    pacho is offline Member
    Jan 2005
    S.C.
    124
    I'm building a box for my 2 Atlas 15"s and the port dimensions are 7" wide with a 1st height of 17" and 2nd height of 12.5".
    --The port is slotted and I'm tuning it to 33 Hz w/7 cubes net, but my question is when im figuring the tuning for the port at this site:
    http://www.carstereo.com/help/Articles.cfm?id=31
    ...since I have 2 different heights, should I add the two heights and divide by 2 to use 14.75" for height??
    Thanks for all responses.
    pacho's Avatar
    Jan 2005
    S.C.
    124
    Re: Will tuning change with this?
    It's actually 1 slotted port in the middle of a box with a 15" Atlas on each side of the port. The mouth is 17" high by 7" wide, but the top of the box slopes down with the depth and that's why I have two different heigths in the port.
    -Help anyone?
    Decipha's Avatar
    Decipha is offline www.EFI Dyno Tuning.com
    Mar 2005
    New Orleans, LA
    29
    3,265
    2 Post(s)
    i would go with a round circle port using a pipe
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    29
    2,211
    17
    i dont understantd why no one uses a pvc elbow to create an "L" circle port.
    pacho's Avatar
    Jan 2005
    S.C.
    124
    the decisions already been made for the slotted port so the only thing I have to worry about is the tuning problem?
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    That port will be near impossible to tune. It would have to remain constant. I recommend you use PVC.
    Quote Originally Posted by Scoobydoo View Post
    Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
    Irony?
    Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. Irony indeed.
    Sep 2004
    29
    2,211
    17
    Quote Originally Posted by tRiGgEr
    check out sample in sig. i designed a wedged box with a slot port.
    pacho's Avatar
    Jan 2005
    S.C.
    124
    Near impossible can be done
    -I'm just trying to figure out what height I'm going to plug in to that site /\ if it should be the mouth of the port, the 12.5" part or 14.75"??
  9. #9
    pacho's Avatar
    Jan 2005
    S.C.
    124
    If one of ya'll can tune the box to 33 Hertz w/square slotted port with a 7" wide port mouth X 17" height port mouth with a 2nd height at the back of the port being 12.5" and the box being 7 cubes net. The box is already made-the only thing I can change is the length of the port, already have the port mouth dimensions made so can't change that. If anyone could instruct me how to tune it to 33 Hz by using that site /\ -it would be greatly appreciated and I might throw something your way.
  10. #10
    tRiGgEr's Avatar
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Quote Originally Posted by bcarpenterfhl
    All you would really have to do is calculate for the right triangle of where the box actaully starts to slant. To much work for free, for me.
    Irony?
  11. #11
    pacho's Avatar
    Jan 2005
    S.C.
    124
    I'll throw something your way if you can help me out-
    Edit-I was just wondering since I'm putting two boxes in my car-if I kept the tuning the same on both boxes but had different sized port areas: say 98^2 port area on one and 114^2 port area on the other-would I be running into cancellation issues or is that only when the tunings are different?
  12. #12
    Sep 2004
    29
    2,211
    17
    Quote Originally Posted by Jmac
    My wedge slot design is much easier ...
    care to share? theres nothing really too complex about the one i did.....
  1. Tuning the Nakamichi CD 400
    By jonno in forum Head Units
    Last Post: 01-12-2005, 04:10 PM
  2. CD-5444 Sub won't change volume on non-fader
    By sanosuke001 in forum Head Units
    Last Post: 01-06-2005, 09:15 AM
  3. TOTALLY Confused About Box Tuning
    By Str8Up in forum General Discussion
    Last Post: 12-28-2004, 06:13 AM
  4. The Subwoofer Enclosure Tuning Thread
    By LoneRanger in forum Enclosure Design & Construction Help
    Last Post: 11-17-2004, 09:25 PM
  5. Tuning at 40-45 Hz
    By Clarion_Guy in forum General Discussion
    Last Post: 12-09-2002, 08:42 PM
