Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Reload Thread: Would you trust this wood joint?
    Nov 2004
    Grove City, OH
    31
    2,236
    Red is wood glue
    Blue is silicone caulking
    Green is a screw
    There are three pieces of .75" MDF, viewed from the side. One piece is under the other two, joining and holding them together. The piece on the underside would be around 2" wide.
    Would this be strong or not be able to hold? Using a single piece of MDF is out of the question... Is this a good way to combind two pieces of wood to make one?
    Thanks,
    Brian
    mustangowner's Avatar
    mustangowner is offline still wangin'
    Mar 2005
    Shelby,AL
    34
    609
    1 Post(s)
    Re: Would you trust this wood joint?
    It looks ok to me...if its goin to be one side of a box i would put extra bracing on the inside of the box around the area of the joint.
    2000 Mustang GT Coupe (yeah, it's mean)
    Headunit -Pioneer deh-p6700mp
    Amp - Power Acoustic A1800db @ 2 ohms
    Subs -RE Audio 10" SE
    Box -at home in a ported box @ 1.5 cubic ft. net tuned to 33 hz
    Components -factory mach 460
    Electrical System -Stock with "BIG 3" (2 gauge wire)
    Wiring -4 Gauge Power & Ground
    REFS: Ridnclean, schrummy, hrtbrk1, mr_kebo, Ridinhi, kharps, mk_, corto
    Quote Originally Posted by Blunt
    why is it that all these idiots wanna be heard from blocks away? Do you buy your system for everyone else or for yourself?
    2wheeler's Avatar
    2wheeler is offline Senior VIP Member
    Mar 2005
    noyfb
    263
    The only thing I would change is to use moisture curing urethane (gorilla) glue for the entire joint, then silicone seal the edges after the joint has dried. Predrill all holes, etc.
    jacko's Avatar
    jacko is offline CarAudio.com Elite
    Mar 2005
    rogers, MN
    29
    584
    depends what the piece of wood is going to be supporting/doing. if you want more strength, make the bottom MDF a bit longer and use 2 screws on each side.(or 4 screws each side if your going to be going 2 screws over the width of the wood, which I would reccomend.)
    GCAdidas13's Avatar
    GCAdidas13 is offline heh.
    Nov 2004
    Grove City, OH
    31
    2,236
    Yeah - there IS blue on the bottom (inside) of the wood joint... over near the edges of the red on the picture.
    GCAdidas13's Avatar
    Nov 2004
    Grove City, OH
    31
    2,236
    Quote Originally Posted by jacko
    Basically what I think I have to do, is build two halves of a box, drop them both in my trunk separately, and then do something like that to screw and glue them together.
    jacko's Avatar
    Mar 2005
    rogers, MN
    29
    584
    i would trust it as long as it was braced from where the joint meets to the other side of the box wall, or 2 braces angled to the floor or roof or sides of the box from where the joint is.
    jacko's Avatar
    Mar 2005
    rogers, MN
    29
    584
    (or on either sides of the joint)
  9. #9
    amedeuce's Avatar
    amedeuce is offline :crap:
    Jan 2004
    CA
    1,791
    3 Post(s)
    All you need to do is glue and clamp those edges together and let it cure overnight.
    References
    Sold to
    jamesdean,jonny101abc,LowLinc,bumpinaintEZ,TurboDu devr4,SVTRELAMPAGO,mk_ ,Burnout956,bonesninja,yenwen,bhsdriller,dalucifer ,BoondockSaints,WillyG4444, alfmoney,btnhfan,dB Dom, mazdakid, giltyler
    Bought From
    TeamPSI,ace_800, Zxcvtypo,bjfish11,atoz350,timbre-audio,Derrick824, lastcall,eclipsefool,rtillaree,PioneerPimp,6spdcou pe,ctmike,Thieroff
  10. #10
    vosschs's Avatar
    vosschs is offline Banned
    Oct 2004
    just east of STL
    30
    5,658
    do you have acces to a biscuit cutter? im sure that would work but if you do have access to one id use that, it holds it and makes the joint almost stronger than the mdf itself
  11. #11
    GCAdidas13's Avatar
    Nov 2004
    Grove City, OH
    31
    2,236
    Quote Originally Posted by vosschs
    Thats what I like to hear. THX
  12. #12
    WheresTheButta's Avatar
    WheresTheButta is offline CarAudio.com Elite
    Mar 2005
    Cranford, NJ
    35
    559
    9 Post(s)
    what's a biscuit cutter?
  13. #13
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    36
    368
    Biscut cutter cuts a small section out of the wood to fit a small peice of wood into it. with glue it joins the insides of both peices fo wood.
  14. #14
    GCAdidas13's Avatar
    Nov 2004
    Grove City, OH
    31
    2,236
    my guess is that it cuts wood in a jagged fashion
  15. #15
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    this is a biscuit joint (id make the 'biscuit' larger tho)
    or you can do a tongue and groove (just get the router bits)
    here is a bridle joint - pretty similar, but bigger tongue and groove. not sure how well it would work with MDF tho.
  1. What kind of wood for box?
    By Inferno13 in forum Subwoofers
    Last Post: 01-22-2006, 01:15 AM
  2. what kind of wood should i use for the following project...
    By noob with an RS in forum Enclosure Design & Construction Help
    Last Post: 04-13-2005, 05:48 PM
  3. Why should I trust adire audio?
    By dan7532 in forum Subwoofers
    Last Post: 10-01-2004, 01:29 AM
  4. wood question for ya'll
    By italianlifter17 in forum General Discussion
    Last Post: 09-27-2004, 01:56 PM
  5. Wood Type
    By plazman in forum Enclosure Design & Construction Help
    Last Post: 09-22-2004, 11:48 PM
