Results 1 to 7 of 7
Reload Thread: Tee Nuts?
    Feb 2005
    Waco, TX
    65
    Icon32 Tee Nuts?
    Today i built my box (MDF) for my two Soundsplinter RL-p's.(letting it cure for a day)
    When i go back tomorrow to bolt the subs in should i use tee nuts or not...the subs r pretty heavy (35 pounds)
    98' Dodge Ram Ext. cab
    H/U: Clarion DXZ945MP
    Front Speakers: Infinity Kappa 693.5i
    Back: Infinity Kappa 63.5i
    Speaker amp: JBL 300.4
    Sub amp: PA A3000DB
    Subs: 2 12" SoundSplinter Rl-p's 1.2 ft^3/side sealed
    --Load Boss HO alternator 205a
    120 ft^2 eDead
    48 ft^2 Dynamat extreme
    TWhitesideLL07's Avatar
    TWhitesideLL07 is offline Member
    Feb 2005
    Waco, TX
    65
    Re: Tee Nuts?
    bump
    Sub amp: PA A3000DB
    120 ft^2 eDead
    UndercoverPunk's Avatar
    UndercoverPunk is offline Super Mod
    May 2004
    Dayton, OH™
    15,663
    Re: Tee Nuts?
    Don't bump something 22 minutes after you create it, just... don't do it...
    As for the T-nuts, I wouldn't do them unless you plan on having the subs in and out of the box quite frequently, or unless you just want to... 35lbs isn't too much for 8 screws to handle.
    Caraudio.com - Where the average member couldn't wire a SPST toggle if they had to.
    More proof.
    Quote Originally Posted by Andrew_as View Post
    I need a program or something that will help me find mounting depth without having to build box and such...
    No, Andy, I'm sure the context is fine.
    Feb 2005
    Waco, TX
    65
    Re: Tee Nuts?
    ok thanks ...sry about the bumping i needed to kno before i went to bed so i could return the tee nuts
    Sub amp: PA A3000DB
    120 ft^2 eDead
    May 2004
    Dayton, OH™
    15,663
    Re: Tee Nuts?
    Noah has his 18" XXX secured in with screws, if they can handle that thing with a MTX 1501d on it, they can handle an RL-P. If you already have em use em...
    nothing like KNOWING your sub is more than secure... bolt the box down and use security bolts to hold the subs in, that's make it way harder to get out unless you had the right driver, and most theives won't have security drivers...
    More proof.
    kenstewart's Avatar
    kenstewart is offline Member
    Apr 2005
    San Antonio, TX
    45
    Re: Tee Nuts?
    For my edification, what does it mean when someone "bumps"?
    LightningStryk7's Avatar
    LightningStryk7 is offline Senior VIP Member
    Mar 2005
    Colorado
    279
    Re: Tee Nuts?
    when they post another post saying anything that brings it to the top of the forum area.
    I have just bumped this thread.
    Car: 1999 Plymouth Neon
    Head Unit: Alpine CDA-9853
    Components: RE RE comps in some custom kick panels.
    Subs: 1x Alpine Type R 1242D In a vented 33 hz 3cuft box. (redesiging)
    Sub Amp: 1x Alpine MRD-M301 mono amp (400 rms/14.4volts @ 2ohms)
    Speaker Amp: Infinity 7520a (97 rms x2 /14.4volts @ 4 ohms)
  1. Stereo's gone nuts - Tech heads please help
    By sgt_nemesis in forum Wiring, Electrical and Installation Help
    Last Post: 02-04-2005, 02:10 AM
  2. JBL 1200.1 amp is nuts
    By muffmanaj in forum Amplifiers
    Last Post: 02-25-2002, 09:40 PM
