Hey, just looking for specs on an SQL enclosure for a Bhrama MK II 15. Port volume, cubic feet, etc. Or just flame me for not paying a competent party for an awesome design...![]()
Thanks in advance.
Thanks in advance.
I com to lern bout car awww-deeeee-ohhhhhs!
Truck: 1998 Ford Ranger SC 2.5L 4 cyl 5 spd
Mods- 195/60R15 Cooper Cobra Tires on stock rims
System: HU- Eclipse CD8454, 2 Dayton RS180 7" midbass, Optimus 3" Horn Tweets hotglued to the dash, 3 12" JL W6v1's downfiring sealed, PPI PCX2200 @ 4 ohms, Alpine MRV-F545 mids and highs, 2 layers of Raamat on the doors.
What's in Store:
2 more Dayton RS180 7" midbass, 2 Bolender Grabender Neo planar tweets
Well here are the typical ?'s
How much room? Type music? How much power you gonna feed it? Blah blah blah............More info will help people.
References
Sold to jamesdean,jonny101abc,LowLinc,bumpinaintEZ,TurboDu devr4,SVT RELAMPAGO,mk_ ,Burnout956,bonesninja,yenwen,bhsdriller,dalucifer ,BoondockSaints,WillyG4444, alfmoney,btnhfan,dB Dom
Bought From TeamPSI,ace_800, Zxcvtypo,bjfish11,atoz350,timbre-audio,Derrick824, lastcall,eclipsefool,rtillaree,PioneerPimp,6spdcou pe,ctmike,Thieroff
H/U Alpine 9887
Mids Seas ER18RNX
Tweets LPG 25NFA
Subs 2 10" Memphis Audio Shallow Mount Subs
Mids/Tweets Amp Kicker ZX850.4
Sub Amp Kicker ZX1000.1
Oh I just saw the amp listed in your sig. The painted to match car ampis the one you'll be using???
References
H/U Alpine 9887
Mids Seas ER18RNX
Tweets LPG 25NFA
Okay, sorry, that was a post and run.
The vehicle in question is a Ford Escort Station Wagon. The Porsche wont be done till August.
The amp in question has now changed: It's the Clarion DPX100.2. 1000 watts (give or take, prolly like 500-600 rms). The other one ended up in my friend's 'Burban.
I listen to generally everything. Metal (mostly), rap, jazz, techno, 80's whatever suits the mood.
THe setup i have now is literally painful. I would like something that will hit hard when it has to, but will have good all round SQ, and won't sound corrosive, sloppy and metallic like the one I have now. I am pretty much done ruining my eardrums.
I have anywhere from 2 cubes to 10+ cubes. The lighter the better, so i was thinking 3 or four cubes ported at about 28 htz should work nicely. I am going to probably attempt to fiberglass it somewhat, just for the experience.
What's in Store:
Why port a 15" if you want SQ? Sealed on a 15 would produce a lot of low end.
Comming Spring 2009
I make rear-loaded, double crabshell, isobaric enclosures.
Actually, I was thinking on making the box ported and the right size and dim's for all out SPL , then make a port cover. I saw a sweet way to do it and just have to try it... Ported to SQ freq would be allright too, but read this:
What they did was took regular bolts (like you could buy anywhere) pretty skinny long ones (with nuts and 2 washers apiece). They made the port cover about 1.5" bigger on all sides so there was some overlap to work with. They drilled holes through both pieces of wood where they wanted the port cover to sit. Then they JB Welded the nuts lined up in the holes on the other side of the box, overtop of one of the washers (lots of Jb weld and scoring onthe surface of the MDF so she sticks good). Then, to cover the port all you had to do was stick the bolts through and tighten the cover down. It sealed very well, they had a rubber gasket as well. When you wanted to turn her loose, all you had to do was take the bolts out, take the cover off, then put the bolts back in the holes.
What do you think?
What's in Store:
Bump... Bump...
I will mail the person who helps me out alot a free 10" woofer.
Would like to build the box soon, any suggestions, comments, or constructive flaming is welcome.
What's in Store:
(triple post)
Well, does anyone know where I can buy a box designing program? I don't need anything but the math, just the internals so it sounds right...
What's in Store:
Bookmarks
