Results 1 to 2 of 2
Reload Thread: Power HX2 Box for SQL
    Buckshot's Avatar
    Buckshot is offline CarAudio.com Elite
    Jan 2005
    Michigan
    563
    I plan on purchasing another power HX2 for the setup in the ol' venge, but I really don't know what the best SQL setup will be. I think I could get ~3.5cu ft, MAYBE 4 if I try real hard. I want to go with a dual ported setup, probably tuned to somewhere around 35 Hz.
    How should I go about doing it? Seperate chambers tube ports? Slot ports?
    a 3.5 cube box with both drivers stuffed in it and a common port?
    Give me your input guys!
    ax600's Avatar
    ax600 is offline CarAudio.com Elite
    Mar 2005
    grand forks N.D.
    696
    1 Post(s)
    Re: Power HX2 Box for SQL
    Do you want to but a power Hx2 15'' Pm me if interested
    I ran mine in 3.5 cuft with 4 -4.5'' ports 18'' long, It sounds great.
  1. Power & Torque
    By Acidburn in forum Car Performance and Repair
    Last Post: 04-26-2005, 05:34 PM
  2. box for 4 hx2
    By Sspider in forum Subwoofers
    Last Post: 10-03-2002, 12:08 AM
  3. Replies: 1
    Last Post: 07-09-2002, 12:15 AM
