Results 1 to 5 of 5
Reload Thread: Can a 12 be mounted on a 12x12 ?
    Decipha's Avatar
    Decipha is offline www.EFI Dyno Tuning.com
    Mar 2005
    New Orleans, LA
    30
    3,265
    2 Post(s)
    Is it possible to mount a 12" that has a 11 1/8 cutout on a 12 x 12 MDF board without the sides overlapping the end of the board??
    I'm going to build a box and need to save as much space as i possibly can.
    ~Magick_Man~'s Avatar
    ~Magick_Man~ is offline CarAudio.com Veteran
    Apr 2005
    bedford,Tx
    32
    2,149
    Re: Can a 12 be mounted on a 12x12 ?
    just maybe, look on the driver manufacturers site for the sub you have and see what the outside dimension is, or just check it with a ruler/tape measurer.
    and if it is 12 or less than yes, if it is more then no
    also what thickness of mdf are you using? atleast 1/2 i would guess and if that is the case then you have 11" inside of the box so you would need to sand/cut the inside of the walls to acomidate for the cut out dimension
    i would recommend having the sides of the box attached to the sides of the 12x12 so the external is 13" and you shouldnt have to worry about the sub over hanging or it hitting inside the box. but that is just me.
    ~Magick_Man~
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    34
    13,810
    probably could be done, but youre not gonna want to.
    12" minus 11 1/8" = 7/8". divde that by two = 7/16" on each side of the box. a little bit on the thin side,not to mention the way the box is constructed youre going to run into the sides of the box and the wood that is associated with that.
    just shape the box differently and do it properly...
    Decipha's Avatar
    Mar 2005
    New Orleans, LA
    30
    3,265
    2 Post(s)
    alright thanx, yall just saved me a bunch of headaches.
    pw91686's Avatar
    pw91686 is offline CarAudio.com Elite
    Jan 2005
    Mobile, AL
    1,110
    1 Post(s)
    53 Post(s)
    most likely not, most 12" subwoofers have a diameter of about 12 1/2" for the total diameter of the sub....
    2004 Honda S2000
    Pioneer DEH-80-PRS
    new build in progress (most likely audison voce av k6, tc sounds tc-1000 8, phoenix gold ti21600.5
  1. GOT MY MOFO 12 and OMG
    By generalGOTCHA in forum Subwoofers
    Last Post: 04-20-2005, 12:40 PM
  2. 12 or 15 xxx better than 2 12 type r's
    By 88k5blazer in forum Subwoofers
    Last Post: 01-27-2005, 08:07 PM
  3. 12 Li or 12 SE or 12 ( blank)
    By supa_c in forum Subwoofers
    Last Post: 01-23-2005, 04:26 PM
  4. Replies: 4
    Last Post: 07-26-2002, 12:39 AM
  5. 12'
    By avistar23 in forum Subwoofers
    Last Post: 12-23-2001, 11:57 PM
