Results 1 to 7 of 7
Reload Thread: which is better. using terminals or running wire direct to sub?
    Pineapple's Avatar
    Pineapple is offline Senior VIP Member
    Apr 2005
    San Jose, CA
    160
    i notice in some sealed subs, people dont use terminals, they have a wire directly connected to the sub and running out of a little sealed hole.
    my friend says it slighty better to have a direct wire because its a pure connection to the sub, it doesnt need to run through a terminal. there wouldnt be any noticeable differance with using a terminal right?
    2002 Tahoe LT
    Pioneer Premier DEH-P860MP
    Diamond Hex S600a
    Diamond M661 (components)
    JL Audio 450/4
    JL Audio 500/1
    JL Audio 12" w6v2
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,691
    Re: which is better. using terminals or running wire direct to sub?
    I use terminals...if you wire it correctly, there should be no difference.
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    only problem i see with running the wires direct is you end up using alot of goop to get a good seal becuse when you bend the wires you create a hole. it might help if you use a bit every so slightly larger than the wire or one the same size and "ream" the hole a bit.
    Car: '97 Crown Victoria P71
    HU: Pioneer Avic X710BT
    Front stage: want bravox CS603CF
    Front stage amp: want powerbass XTA 2240
    Substage: 15" FI BL fully loaded in 3.5 cubes @33hz firing through rear deck.
    Substage amp: Powerbass XTA 1500D
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,857
    I drilled a tiny hole just big enough for the (10GA) wires to pass through the MDF - keep it snug and it should work fine - no sealent ness
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Midwest Ohio
    26
    3,509
    i use terminal cups when the wires are running out of the box are going to be seen. Just a cleaner look IMO.
    But when they are not going to be seen i get the drill and caulk gun out and make a hole and seal the ***** out of it.
    They both are going to perform the same.
    One just looks better than the other.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    lotas's Avatar
    lotas is offline CarAudio.com Elite
    Nov 2004
    Washington
    513
    i hate terminal cups, i wouldnt use them unless you really love the look of them, or you are building an enclosure for someone who wants them.
    its just added time, wasted money. I mean you have to cut the hole for them, fit them, screw or liquid nail them, caulk them. then you have to deal with air leaks, and you have to solder or connect the wire from the sub to the inside of the terminal cups, i mean its just added work.
    I think it would look cooler to have a sub box with nothing on the side, wire going out the back, then a sub box with terminal cups and wire coming out. personal opinion though.
    Pioneer, JL Audio, Bravox, Peerless
    HAVINGFUN's Avatar
    HAVINGFUN is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    I like them because they look better and you do not have to unhook wires from the amp everytime you want to screw with it. If they are good terminal cups they will not leak and they only cost like 3 or 4 bucks. I think people are just lazy and impatient. It is the same reason people do not carpet boxes, it is a pain in the arse but it looks better. If you are worried about air leaks just take a bunch of bondo and cover the inside of the box where the terminal cup is.
    your mom goes to college
  1. Running speakers wire thru doors
    By NE14MX in forum Wiring, Electrical and Installation Help
    Last Post: 03-12-2005, 02:22 PM
  2. Magnet degrade signal when speaker wire close?
    By Savant in forum Wiring, Electrical and Installation Help
    Last Post: 01-17-2003, 07:50 PM
  3. need help 6x9 speakers installation
    By kirstin in forum Wiring, Electrical and Installation Help
    Last Post: 12-27-2001, 12:50 AM
  4. Running new speaker wire
    By <Muff DVR> in forum General Discussion
    Last Post: 12-22-2001, 05:30 AM
