Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Need help with box.
    Jeb's Avatar
    Jeb
    Jeb is offline Member
    Dec 2004
    AR
    85
    Need help with box.
    I have two Audiobahn 1206t's and I need to build a box for my civic. I've tried using George's tutorial but didn't make it very far... (I don't know what I should tune the box to, etc.) I currently only have the 12's on 500 RMS each. I'm not sure if I should go sealed or ported considering the 12's handle 1100 RMS a piece. My max dimensions for a box are 15hX28wX34d. The Audiobahn specs are listed below, if anyone could help me get started I'd greatly appreciate it.
    Audiobahn Box Specifications
    All ports listed are circle ports unless otherwise stated. Surface area of a circle port = (3.14) X (radius) (squared)
    Remember to build your box to the total volume, not just air space, as total volume includes all displacement.
    Model # AW1206T
    Space Saver Bass Design
    Ported Air Space (Cu. Ft.) 1.3
    Port Size (Inches) 3 x 6.75
    Port Vel. (%) 34.65
    -3dB (Hz) 35
    Tune Freq. (Hz) 40
    Sub Disp. (Cu. Ft.) 0.25
    Port Disp.(Cu. Ft.) 0.024
    Total Vol. (Cu. Ft.) 1.5
    Everyday Bass Performer
    Ported Air Space (Cu. Ft.) 2.3
    Port Size (Inches) 4 x 7.25
    Port Vel. (%) 19.6
    -3dB (Hz) 32.5
    Tune Freq. (Hz) 38
    Port Disp.(Cu. Ft.) 0.046
    Total Vol. (Cu. Ft.) 2.5
    Ultimate SPL Bass Box (Not Designed for Competition)
    Ported Air Space (Cu. Ft.) 3.2
    Port Size (Inches) (2) 4 x 12
    Port Vel. (%) 9.65
    -3dB (Hz) 30
    Tune Freq. (Hz) 36
    Port Disp.(Cu. Ft.) 0.165
    Total Vol. (Cu. Ft.) 3.5
    A port velocity of 20% or under is good for everday use and 5% or under for SPL competition . Port velocity
    translates to port noise, so the lower the number, the less port noise you will incur.
    An EBP of less then 45 is SUGGESTED for only a sealed box and greater then 65 for a ported box.
    EBP 80
    The larger a sealed box is, the lower the sub will play, but the less power it will handle. The smaller a sealed box
    is, the higher the frequency the sub will play, and the more power it will handle.
    Model #1206T
    Sealed Minimum (Cu. Ft.) 0.5
    Maximum (Cu. Ft.) 1.25
    SPL (dB) 84.9
    All sealed boxes already include the displacement for the subwoofer. NR = (Not Recommended)
    Revised June 2, 2003
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    30
    2,211
    17
    Re: Need help with box.
    assuming you want them to be loud as possible, and because they're greatly underpowered, i'd go ported, you have the space for it.
    Jeb's Avatar
    Jeb
    Dec 2004
    AR
    85
    what would be a good tuning freq. for these subs?
    Sep 2004
    30
    2,211
    17
    depends on what sound you're looking for. 20-30 hz for sq, 30-40 for sql, and 40-50 for spl.
    Jeb's Avatar
    Jeb
    Dec 2004
    AR
    85
    I'm looking for that deep sounding bass that you feel in your chest. So about how many hz would that be?
    swaptrex's Avatar
    swaptrex is offline Supporting Member
    Nov 2004
    Michigan
    31
    2,014
    Quote Originally Posted by Jeb
    1,000,000,000,000 hertz
    jk, 32 is a good number
    Jeb's Avatar
    Jeb
    Dec 2004
    AR
    85
    how about 28hz?
    Sep 2004
    30
    2,211
    17
    28 would hit the lows pretty good. what music do you listen to?
  9. #9
    Jeb's Avatar
    Jeb
    Dec 2004
    AR
    85
    rock and rap
  10. #10
    Sep 2004
    30
    2,211
    17
    yea 28's good if you want to be able to really hit those lows.
  11. #11
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    28Hz would be a good tuning.
  12. #12
    Jeb's Avatar
    Jeb
    Dec 2004
    AR
    85
    I've tried using George's design walkthrough... but I don't completely understand what I'm doing... So I know my max dimensions and what I want the box tuned to... what do I do next?
  13. #13
    Sep 2004
    30
    2,211
    17
    did you want to use a slot or pvc pipe?
  14. #14
    Jeb's Avatar
    Jeb
    Dec 2004
    AR
    85
    I'd like to slot port
  15. #15
    Sep 2004
    30
    2,211
    17
    you're gonna have a really hard time figuring all this out quickly. you have to use trial and error. establish your port area, calculate your box volume with sub displacement, try a port length, calculate port displacement, subtract that from box volume, and calculate frequency.
  1. Designing a ported box with George
    By IgnoreMe in forum Enclosure Design & Construction Help
    Last Post: 06-03-2005, 07:18 AM
  2. Box Builders look
    By KARLEON in forum Enclosure Design & Construction Help
    Last Post: 11-20-2004, 02:17 PM
  3. My 13kv2 ported box! (pics)
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-18-2004, 09:31 PM
  4. Ported Truck Box 2 alpine 10's
    By Jearod in forum Enclosure Design & Construction Help
    Last Post: 12-01-2002, 08:53 PM
  5. Ported Box for Kicker 12'' L7
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 07-05-2002, 02:03 PM
