Results 1 to 6 of 6
Reload Thread: 3 way compnent question
    PaLiAcH's Avatar
    PaLiAcH is offline Member
    Jan 2005
    SoCal
    69
    Icon32 3 way compnent question
    for a 3 way component setup, does the tweeter and the midrange both have to be in kicks? or can u put the woofer in the door, the midrange in a kick by itself and the tweeter in the a-pillar?
    reason i ask, is ive got fatory tweeters in the a-pillar, and not much room for big kicks (being a manual trans)
    also, is a 2nd amp needed? one for woofer and one for mid/tweets? or can the 3 way be run off one amp?
    thanx for the help guys!!
    -pino
    cobra133's Avatar
    cobra133 is offline Member
    Mar 2005
    Atlanta, GA
    28
    71
    Re: 3 way compnent question
    You can mount the seperately. If you want to get the most out of your components, you should use an amp on them. If you want good sound, don't skimp on the amp.
    I'm looking to buy some really nice components. 6.5" with 1" tweeters. PM me.
    PaLiAcH's Avatar
    Jan 2005
    SoCal
    69
    yah they wil be amped, but ill need two, right? one for mid-range/tweet (with crossover) and one for midbass in door?
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Assuming you are just buying a regular 2-way comp set, then "adding" a dedicated midbass to them.....yes, you will need two amps. Run one amp to the 2-way set, then the separate amp to the midbass to allow you to cross them over separately.
    And, if possible, you should "mock up" the tweeter in both locations and see which way gives you the best performance. As a general rule of thumb, you want the midrange and tweeter as close as possible. And generally a-pillar mounted tweets normally works best when the tweeter is crossed over very high (like 7khz+). Again, that's generalities. Never know....you may like your tweets being in your pillars with a "normal" crossover point. Just mess around with it if you can.
    PaLiAcH's Avatar
    Jan 2005
    SoCal
    69
    yep squeaks, ill be getting the alpine type x 2 way comps (SPX-177R) and adding a dedicated midbass...
    would these work for the midbass? Alpine SPX-17MB? they are basically the alpine type x without the tweeter... but they do have a crossover... is that overkill? or do i need to go with sumthin else?
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Well, they would work. Don't know if they would be my first choice for dedicated midbasses.....but it would work
  1. '95 Camry upgrade: DIN question and stock speaker cover removal
    By Llamas in forum Wiring, Electrical and Installation Help
    Last Post: 06-01-2005, 01:41 PM
  2. Amp Power Question
    By stuwad21 in forum General Discussion
    Last Post: 03-12-2005, 11:14 PM
  3. Simple Amp question... I think
    By TexasA&M in forum Wiring, Electrical and Installation Help
    Last Post: 10-20-2004, 12:59 PM
  4. Replies: 5
    Last Post: 08-08-2002, 01:14 PM
  5. Hypothetical warranty question for you guys...
    By wesleysh in forum General Discussion
    Last Post: 08-01-2002, 03:36 AM
