Results 1 to 8 of 8
Reload Thread: 15" Mofo Enclosure
    theCybe's Avatar
    theCybe is offline sector three
    Dec 2004
    Columbus, OH
    6,004
    15" Mofo Enclosure
    My MOFO should be here tomorrow.
    PA recommends 3.5 @ 40 - I say blasphemy, I want 33hz.
    Should I be adjusting the volume?
    Goldtaz1's Avatar
    Goldtaz1 is offline CarAudio.com Elite
    Jun 2004
    Montgomery, AL
    37
    1,693
    1 Post(s)
    Re: 15" Mofo Enclosure
    Manufacturer recommendations are just that; Recommendations. You can build your box (within reason) to almost whatever you feel like. I'm not saying to try to build a ported enclosure for a 15" driver with only 2 cubic foot, but you could use their recommendation of 3.5 cubes and tune your box to 33 Hz. Besides, 40 Hz and higher is almost getting to the point of straight SPL rather than daily music listening. A good musical tuning is usually between 30 and 35 Hz. Just remember net cubic volume and tuning greatly detertermine power handling of the woofer.
    HU: Sony Xplod MP80
    Highs and Mids:
    Infinity Kappa series 63.5i
    Infinity Kappa series 572.5cf
    Subs: (3) Incriminator Audio DP 15's
    Sub amps: (2) Crunch GP3000D Pro's
    This one is ridiculously LOUD !
    References: Bamaboy, AZ-ss, 9512ds, and DRCKISS
    theCybe's Avatar
    Dec 2004
    Columbus, OH
    6,004
    [ blink, blink. ]
    Goldtaz1's Avatar
    Jun 2004
    Montgomery, AL
    37
    1,693
    1 Post(s)
    Does that mean you did not understand my comment?
    HU: Sony Xplod MP80
    Highs and Mids:
    skeptikal's Avatar
    skeptikal is offline Hold the wheel and drive skeptikal is a Supporting Member of the forum!
    Jul 2004
    Indiana, US
    4,066
    22 Post(s)
    those things will handle whatever power you plan to throw at it as long as you gain it correctly. dave's got his in 4.5 cubes each @ 36Hz (iirc) and gots an a3000db on each one.
    2005 Dodge Ram Quad Cab
    Pioneer DEH-80prs
    Image Dynamics X-65
    Image Dynamics XS-28
    PPI 900.4
    Wolfram 1500.1
    Sundown Audio SA-12 D4 (x2)
    Noico deadener
    NVX wiring
    theCybe's Avatar
    Dec 2004
    Columbus, OH
    6,004
    Well, my condition is this.
    The maximum outer dimensions for a box that I can actually fit through the trunk opening are:
    35 x 13 x 19.
    I already have such a box, and it's sealed.
    We'll call it 4 cubes after bracing and the woofer's displacement;
    The box also has two 3" diameter holes, for ports.
    How long should the ports be for 30hz? 35? 40?
    That's my dilemna.
    the12volt.com reports a portlength of just over three inches, for a single 3" diameter port.
    I realize the ports will eat up some of the box volume, which is fine by me - the manufacturer suggests a 3.4 cube, tuned to 40Hz; Their port information is something like two 3" dia ports @ ~10 inches.
    the12volt.com's calculator reports a single 3" port at only .75 inches for 40Hz; Which is equal to the depth of the wood;
    What am I missing?
    How long should each port be, to achieve 30-35 Hz?
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    WAY more port cross sectional area. take the SD of the woofer, cut it in half. thats roughly what you wanna shoot for if you can.
    what are the specs of the mofo 15. i will be building one at porlly like 36hz for it because its a 60\40 install.
    theCybe's Avatar
    Dec 2004
    Columbus, OH
    6,004
    I misread; PA's recommendations are for two 4 inch ports at 8.25" each.
    So given a box volume of 4 cubes after driver displacement, how's 1.5x13.5x11 for a slotport?
    The specs are available at http://www.poweracoustik.com/SUPPORT...s2003_pg2.html
  1. 15" XXX enclosure
    By reaudiooutlaw88 in forum Enclosure Design & Construction Help
    Last Post: 12-30-2004, 05:13 AM
  2. Diamond Audio CM3 15" Enclosure size
    By B2000 in forum Subwoofers
    Last Post: 11-05-2004, 06:10 PM
