Results 1 to 4 of 4
Reload Thread: porting question
    stish05's Avatar
    stish05 is offline Member
    Mar 2005
    clintonville, wi
    64
    porting question
    if the manufacturer tells me to port the box with 4" x 16.75", can i shorten the length and still be ok, or should i stick to the man. specs?
    BigPimpin18's Avatar
    BigPimpin18 is offline Member
    Nov 2004
    Seattle, WA
    110
    Re: porting question
    I would stick to the specs. because they built the sub and they know wuts best for the sub
    SPL140.2's Avatar
    SPL140.2 is offline Team DefJ
    Mar 2005
    NY
    40
    5,295
    5 Post(s)
    if your shortening the length of the port it will change the frequency!
    Team DefJ
    http://www.myspace.com/loudinspl
    WWW.JAGGEDEDGEKUSTUMVINYL.NET
    REF'S:
    VOSSCHS-NJACK2AF-WOWIMZZ-DECIPHA-AZNGOTSKILLS-TRAFFICJAMZ-MILLIONARE1-QTRHORSE
    TSL13505-DJL(2)-KNOTSLCK-KYLEC-KNUKONCEPTZ(4)-KEIFERSRACING-TEAM H&K
    ANDRIZZLE-95BLACKGA(3)-MAX_POWER-POUNDINDAK69-DVRMSTRNG-BLONG131-PIMPDADDYQ
    NOPH33RACING-KPR10IS-XTREMEBASSJUNKY-ENVEE 02-J3M CONCEPTS(3)
    CONNERSDAD19(6)-SNOOPDAN(2)-SUNDOWNZ(3)-MRWIGGLEZDJ-ASTYL-BLAZIN_JASON-GOT_FOCUS?
    SPLCHOICE-DBDESIGNSELITE-JEREMY M-GLADIATOR_JAI-QTIPEXTRA(2)-BJFISH11(2)
    MEMPHISFLEX-CHA0-BBALL09124-BUCKYBOY-CURTIS1993-ICPURPLEPPLALOT-BMBORSK-P3BUMPIN-DEFJ165
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    You can shorten it or use pvc with the 90 degree bend (joint) to fit your needs. Look at the port calculator and you can see how the length changes the tuning freq.
    http://media.doitbest.com/products/409820.gif
    http://www.the12volt.com/caraudio/boxcalcs.asp#par
  1. '95 Camry upgrade: DIN question and stock speaker cover removal
    By Llamas in forum Wiring, Electrical and Installation Help
    Last Post: 06-01-2005, 01:41 PM
  2. Amp Power Question
    By stuwad21 in forum General Discussion
    Last Post: 03-12-2005, 11:14 PM
  3. question about ported boxes
    By crzybob77 in forum General Discussion
    Last Post: 09-17-2002, 09:50 PM
  4. Porting Question???
    By dbhittin in forum Subwoofers
    Last Post: 04-07-2002, 05:45 PM
  5. Porting Question?
    By Unregistered in forum Subwoofers
    Last Post: 03-19-2002, 04:09 PM
