Results 1 to 3 of 3
Reload Thread: help with box design
    rtd66stang's Avatar
    rtd66stang is offline Registered User
    Mar 2005
    L.I.,N.Y.
    Icon32 help with box design
    I am new to the forum, and am just getting back into car audio.I am building a box for two 10'' type E subs powered by a RF 8002 amp. The problem is the space I have to work with. The box is going in a '66 conv. Mustang. I want to tuck it up under the top in the trunk.I had to make the box in the shape of a parallelogram 12''x12''x39''. The volume seems to work out right and it fits perfect in the trunk but the woofer does not fit flush in the box because of the depth.Can I just make up a couple of rings to build out the woofer a little,or will this effect the sound and volume. Thank you. Richie
    THUNDERBIRD's Avatar
    THUNDERBIRD is offline CarAudio.com Veteran
    Feb 2005
    LANSING, MI
    2,340
    Re: help with box design
    it will effect it a lil but not a lot
    94' thunderbird *parked*<
    4.6 V8 with a shift kit
    clarion dxz 645mp clarion sirius tuner
    ED 6000v.2- front jbl 5.25 comps- rear
    dynamated and edeaded trunk lid, rear deck, front doors
    Big 3 in green of course
    viper 791xv w/ battery backup
    3 jl 10w0
    2000 ford ranger supercab 3.0v6 4x4
    stock hu
    alpine mrp-m350
    2 9kv.3's
    clifford matrix rsx 50.5x
    spring time getting clarion MAX675VDII and front components possibly jbl's again
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    25
    11,175
    do that......and wrap some fleece around it...and glass it....make sure u glass the rings and let the dry to seal that off. and THEN wrap fleece and glass it. will make for a cleaner install
  1. My Box RE XXX 15 Box Design
    By james33440 in forum Subwoofers
    Last Post: 03-22-2005, 04:47 AM
  2. Need box design help.
    By nc1go in forum Enclosure Design & Construction Help
    Last Post: 03-10-2005, 07:41 AM
  3. need someone to design me a box
    By bonesninja in forum Enclosure Design & Construction Help
    Last Post: 03-10-2005, 04:26 AM
  4. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  5. Box design help
    By jinx8402 in forum Wiring, Electrical and Installation Help
    Last Post: 09-01-2002, 11:52 AM
