Results 1 to 14 of 14
Reload Thread: Carpeting
    BigPimpin18's Avatar
    BigPimpin18 is offline Member
    Nov 2004
    Seattle, WA
    110
    Carpeting
    ok I've carpeted a box before but that was more of the face part of it. so I want to know how you guys do your corners and edges on your boxes. show some pics if you can.
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    Re: Carpeting
    i have no pics, sorry.
    But the best thing to do for seams & edges is a Hot Glue Gun. Absolutly great, sturdy bond.
    -Nick
    What the f00k happened to this place?
    joeldirt's Avatar
    joeldirt is offline Integrity
    Dec 2004
    Eureka, CA
    37
    467
    1 Post(s)
    Re: Carpeting
    _____________________________________________
    Different People, Different Ways...
    Feb 2005
    pinellas park, fl
    107
    Re: Carpeting
    i have a question to .. i see how they did that peice of wood but if ur doing a box and u have to glue the sides of the wood together and stuff what would u do? bc i dont think u can cover the face of the box panel then have it come onto the back which would be in the bow......so then how would u cover the ur whole box??? sorry if i didnt explain that clearly
    joeldirt's Avatar
    Dec 2004
    Eureka, CA
    37
    467
    1 Post(s)
    Re: Carpeting
    Quote Originally Posted by baronfootballer
    I understand you may have gotten confused by that. I wasnt trying to show you that in how to carpet your box by carpeting each individual piece. That guy actually does it different then me, but yet similar...... THat was only to show the concept, not to caprpet each piece then assemble the box. that would be booty. Instead build your box....
    roll out your carpet so that you can roll your box up in it like a roll of tape (well somthing like that.
    begin the carpeting by placing the box down on the carpet with the backing of the carpet facing up. put the very end of the carpet so that it will adhere to the bottom of the box centered. OYu wnat the edge of the carpet to be about center so that you see half the bottom covered in carpet and half the MDF...........
    glue it by using 3M spray adhesive.... spray the carpet that you are ready to aply, then the box area that is about to be covered. let the glue tack up a bit then firmly rub the carpet into place.
    Now that the bottom of the box is started, continue with the box all the way arround until you get back to the bottom again. cut the carpet so that it overlaps about an inch over the begining of the carpet... Adhere it all down and using a razor and straight edge, sut the carpet (cutting both pieces at overlap) and remove the bottom piece. The two ends should meet perfect.....
    Now you need to do the ends of the box.
    At the corners, crease the corners so that the corners of the box extend out with the excess carpet. now with a pair of scissors cut on that crease, and fold two of the ends in..... seal the pieces in and cut the two overlapping pieces like you did the bottom. remove the bottom piece. Now with the other two, stretch one taught, and over the surface, and use a straight edge to cut from the center to corner. removing the under pieces and adhering the top pieces..... you should now have a completely covered box. I hope this helps. I am not very good at explaining what I am trying to say.
    Slody4Futbol's Avatar
    Slody4Futbol is offline CarAudio.com Elite
    Jan 2004
    Jackson, MS
    33
    1,207
    Re: Carpeting
    i've also read you can carpet your box like so... lay your carpet out and wrap it around the box completly... do your cut on the bottom and glue/staple/however you want to secure the carpet 2 your box... trim the edges and staple/glue them to the ends... cut a piece of wood to the same shape and size as your sides... carpet that piece as in that tutorial in the link above... hold that to the end of your box... drill a few screws through that piece from the inside of the box to secure it to the ends...i haven't done it myself... but seems a little easier than cutting it perfectly so the seams fit together
    Been out of this for a longgg time...
    Feb 2005
    pinellas park, fl
    107
    Re: Carpeting
    o ok i kinda understand better now i appreciate it...seems kinda hard aybe bc ive never built a box before.
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    Re: Carpeting
    wrap it like youd wrap a christmas present.
    then when you 'fold' the sides, instead of stapling them down, slice on the seams with an X shape, and cut thru all the layers.
    its kinda tricky- and you needa REALLY sharp knife to get it perfect. maybe ill do pictures of the process.
  9. #9
    Feb 2005
    pinellas park, fl
    107
    Re: Carpeting
    once u cut it and glue it down is it visible that theres a cut there?
  10. #10
    joeldirt's Avatar
    Dec 2004
    Eureka, CA
    37
    467
    1 Post(s)
    Re: Carpeting
    No! that is the whole idea. We hate booty looking installs. we wouldnt incourage you to do somthing that would look like ***. experiment on a scrap and you will see what we mean.
  11. #11
    Feb 2005
    pinellas park, fl
    107
    Re: Carpeting
    o ok i was worried it would be visible thanks alot
  12. #12
    chefboyrlee's Avatar
    chefboyrlee is offline Senior VIP Member
    Feb 2005
    los angeles, ca
    328
    Re: Carpeting
    a carpeting "how to" would be a great thread.
    my 2 cents.
  13. #13
    Feb 2005
    pinellas park, fl
    107
    Re: Carpeting
    i agree bc i think alot of ppl would like that or i would ...maybe with some pics?
  14. #14
    Black_Jesus's Avatar
    Black_Jesus is offline The Unexpected
    Aug 2004
    lamest place humanly possible
    1,743
  1. Carpeting Tutorials?
    By xSomeguyx in forum Enclosure Design & Construction Help
    Last Post: 02-22-2005, 01:15 AM
  2. carpeting boxes....
    By Matt0528 in forum Enclosure Design & Construction Help
    Last Post: 01-26-2003, 08:30 PM
  3. Online Carpeting Availability?
    By BonusBobo in forum Subwoofers
    Last Post: 01-24-2003, 04:35 PM
  4. Carpeting
    By mnkhunter in forum Enclosure Design & Construction Help
    Last Post: 10-28-2002, 11:44 AM
  5. carpeting ideas?
    By Vorak in forum General Discussion
    Last Post: 06-13-2002, 02:52 PM
